Allmakes Parts - Lots of Pics
Here are some new Allmakes parts I think look good.
Water Pump:
Tappets - PR2 - Made in USA
Crankshaft Timing Gear - PR2 - Made in USA by Dynagear
Front Crankshaft Oil Seal - PR2 - Made in France by Corteco
Timing Chain - PR2 - Made in USA by Dynagear
Upper Radiator Hose - PR2 - Made in Malaysia
Oil Cooler Line
Front Cover Gasket - Made in USA
Rocker Shaft
Water Pump:
Oil Cooler Line
Rocker Shaft
With respect to the lifters, the flat spot on oem rod matches the flat spot on lifter. If you used new rods with old lifters, the "ball" would not fully seat, IMHO. Good thing you are doing it all.
While you have spent more on parts and shop than some of us spent on our trucks, you have save quite a bit on tuition for the technical college of auto mechanics.
So much more to learn too.
Savannah, Maybe you should award him an Associate Degree from Thye International School Of Rover Education based upon his achievements so far. Create a nice certificate and send him. He has almost earned the Bachelor's Degree and is headed for a Master's at this rate.
