Alternator retrofit??
Old May 17, 2012 | 09:34 AM
portman5's Avatar
5th Gear
Default Alternator retrofit??
Hi everyone,
I am searching for the best option (good and cheap) replacement for my noisy alternator. Is it possible to retrofit the 130 amp alternator from the Disco 2 into the Disco 1. So far I have not been able to find any information if itle 's possible or not.
The part number in question is LR part # ERR6413
Bosch part # 0-123-510-073
Thank in advance for your help.
Old May 17, 2012 | 10:28 AM
ValveCoverGasket's Avatar
ive heard that its not...
Old May 17, 2012 | 11:47 AM
Jake1996D1's Avatar
GEMS P38 Range Rover - not completely sure what it takes but do some searching..
Old May 17, 2012 | 11:52 AM
Consider getting quote for carry in service at local small alternator / starter shop. Other than the Rangie or another D1 not a lot at the salvage yard that will bolt right on. If you buy reman from parts store chain get one with lifetime waranty, they don't last long and have high failure rate.
Old May 17, 2012 | 12:21 PM
pinkytoe69's Avatar
Wait, so a p38 can be made to work?
Old May 17, 2012 | 12:24 PM
Jake1996D1's Avatar
A P38 with a gems 4.0 or 4.6 should work it's the same engine
I think Tom Rowe posted about have a 120 amp from a Rangie ....
Old May 17, 2012 | 12:44 PM
Jake1996D1's Avatar
Yea I think they are like 120 amp - I should pick one up too at some point mine is whining also.
Old May 17, 2012 | 12:51 PM
pinkytoe69's Avatar
Yeah I know but stuff is on the opposite side, so I wasnt sure.
Old May 17, 2012 | 12:55 PM
Jake1996D1's Avatar
What stuff is on the opposite side? It's all the same disco to p38 as long as it's gems
