Alternator suggestion
Old Mar 22, 2017 | 09:26 PM
cpedraza's Avatar
6th Gear
Default Alternator suggestion
Hi guys,
I have a 1998 V-8 4.0 disco 1. The Bosch alternator has ceased. First I'm not sure if the alternator amp is 100 or 120. Second, I don't know if I buy a more amps alternator (160amps) would damage my ecu?
Any info, suggestion and comment will be greatly appreciated.
Carlos
Old Mar 22, 2017 | 10:04 PM
ihscouts's Avatar
Magnetti Marelli A127i 100amp is OEM. If you can find a GEMS Range Rover P38 it uses the 120amp. Increasing the amperage won't harm the ECU, necessary for things like a winch.
Old Mar 29, 2017 | 09:40 AM
notny41's Avatar
Is the alternator completely shot? I've had good luck when I replaced the voltage regulator on mine a couple years ago (very easy to do and costs about $35 off ebay). Still working like a champ. Before I changed the VR on the back of the alternator my lights would get dim and then bright, I would lose my tachometer or it would jump when lights dimmed or got brighter.
wrongway1
Jun 21, 2017 08:23 PM
mrpcar
Feb 22, 2007 03:17 AM
pcar993
Feb 21, 2007 02:00 PM
dillhole
Nov 12, 2006 03:35 PM
kpxus
May 13, 2006 08:13 PM
