Another lift question
Old May 17, 2012 | 10:31 AM
ValveCoverGasket's Avatar
Originally Posted by ngarover
Right from their site as well....
"Most 4-wheel drive vehicles will require a suspension lift for additional OM617 engine clearance due to factory oil pan design."
I think it might be cheaper and faster to just do the lift instead of dicking with all the engine mods I've seen others have to do...
theres no way to just put a divot or notch in the oil pan?
Old May 17, 2012 | 10:43 AM
ngarover's Avatar
This is already the plan.
Old May 17, 2012 | 10:56 AM
Jake1996D1's Avatar
I vote drop it in and then worry about about what else you have to change to make it work properly
Old May 17, 2012 | 11:16 AM
ngarover's Avatar
Kind of what we are doing, but of course it's much better to no have to reinvent the wheel...
We are actually doing 2 of them at the same time. I drop the truck off tonight at 5 to start the process. Maybe spend tomorrow pulling out the 3.9 and the R380 so we can template the adapter and get it cut, Others have used the 616 MB flywheel, but I think we are going to see about using the rovers flywheel first. If it doesn't work, I have 3 616 flywheels I can have in a couple days.
Then, while we are working on that, get the master kit for the trans and rebuild it so it will be 100% when the job is finished. (currently the synco for 2nd is crappy). My trans place will do the full rebuild for 200 labor if I get them the parts.
I'm selling off my 560sl also to add more money to this build. If I do it, I want it to be done right in the end, something I can have for many years.
Old May 17, 2012 | 05:25 PM
wheelgarage's Avatar
That is a good deal! Have him break down the transmission and see what parts you need. There should be no reason to rebuild the entire transmission. Just replace what needs to be replaced. It will either be the balk or the sync rings, which don't cost that much.
Update when it gets done!
Old May 17, 2012 | 05:28 PM
Since you are an MB guy...
Do you know if I can just swap out the airbag for a coilover system without having any computer issues???
For a 2005 W211 Estate....
thanks and sorry for hijacking....
Old May 18, 2012 | 05:35 AM
ngarover's Avatar
Smile
I'm an 80's MB guy....
Old May 18, 2012 | 10:25 AM
i know that wasnt directed at me, but... i dont think so.
im sure the warning lights will come on.
have you checked over on benzworld? if anyone would know itd be the w211 guys there...
Old May 18, 2012 | 10:56 AM
Yeah...I dont like hanging out there much...too much fluff.
I currently have the kit which tricks the system to the lower height...just want to get rid of the damn thing. I am not looking forward to replacing another bag. Going to hit up the guys in the EU to see what they have done. I know...the dang warning light....maybe if I keep the height sensor in there with the trick bracket, it should continue to think it is at normal height...hummm....
End of session...back to the normal program...sorry for hijacking...
Old May 18, 2012 | 02:43 PM
turf63's Avatar
i have four inches with ome 762/763 and 1" spacers all around. Pretty cheap
Dan7
Nov 28, 2012 09:04 PM
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
mowermechanic
Jun 22, 2009 10:45 PM
Bigmonty
Aug 8, 2007 07:13 AM
