Another Overheater and what what about almininum radiators?
Old May 25, 2018 | 10:33 PM
  #21
Johnny K's Avatar
I bought the Duralast from Autozone. How can you tell if it's always engaged? it has certainly fixed the overheating problem for me.
Old May 26, 2018 | 06:28 AM
  #22
ihscouts's Avatar
You can hear the fan all the time, it's an obvious sound, like an electric leaf blower on high. The fuel mileage will drop like a rock, motor won't have get up and go. Hayden in mine.
Old May 26, 2018 | 06:43 AM
  #23
Johnny K's Avatar
thanks. i didn't notice any distinguishable change in sound, power or MPG. I was expecting to see a drop in MPG and in power, just from having a working fan, but i've seen none of that.
Old May 26, 2018 | 07:25 AM
  #24
ihscouts's Avatar
That's great, it's working as advertised. I know what you mean since I added a fan clutch to my setup, my seat of the pants gauge says I lost a little grunt on take offs. With the A/C on I lost all rocket boost..... but I am comfortable while waiting for it to spool. I have one final suggestion about your setup, you should get an aftermarket temp gauge so you have an accurate reading and then you'll have a good baseline to know when something is amiss. The dash gauge is just fill to round out a dash card, way too slow to be of use.
Old May 27, 2018 | 10:05 PM
  #25
Johnny K's Avatar
so, after reading the above posts. ive been listening more closely to the engine and it seems that the fan clutch is working-- a lot. but, before i make any definitive claims, i want to check mpg on the highway. ive been looking into tuning the fan clutch. my particular clutch is not adjustable, but with a little ingenuity, i think i may be able to do so. but that will be a post overland (KS-PA-TX-KS) project. IHScouts, i purchased an autometer 4337 temp gauge and finally installed it today. i think it may be a road hazard, as i seem to be staring at it more than the hardball, my first conclusion is that the factory gauge cannot determine temps between 190-205. though the autometer tracked the temp rise, the factory gauge hit a point at 190 and stayed there through 205. my temp sensor is located in the rad hose with an adapter. i will install more permanently tomorrow. the truck never peaked more than 205 degrees, but, i think i am extremely lucky . temp gauge has gone as high as about 5/8 of the factory gauge once when sitting in Kansas City traffic. the fan clutch certainly is controlling the temp, though.
What is the general consensus on running a 180 thermostat in a 1995 D1? ive read both, good and not so good. damn this thing is fickle.
Old May 29, 2018 | 12:48 PM
  #26
whiskeynipple0088's Avatar
I have a URO - pile of garbage
it sounds like a jet engine when trying to accelerate -
constantly engaged even at free way speed when its 70* out
in otherwords if you are on the freeway cruising for a bit and get off and still sounds like a jet engine - its not disengaging
AtlanticBritish
Atlantic British
Oct 6, 2017 09:11 AM
AtlanticBritish
Atlantic British
Aug 2, 2017 02:02 PM
AtlanticBritish
Atlantic British
May 10, 2017 09:53 AM
Savannah Buzz
Nov 15, 2012 09:59 AM
Savannah Buzz
Off Topic
Jul 28, 2011 04:42 AM
