Another overheating issue
Old Feb 16, 2012 | 11:36 PM
  #31
TheyseemeRovin''s Avatar
Update:
I worked all evening on the disco, changed the oil and oil filter, fuel filter, air filter, new spark plugs and wires, replaced the fan clutch, and put a 180 degree thermostat, replaced a blinker and took my rad to the shop!!! Now I just realized my key wont unlock or lock my disco. I can lock it from the inside, and all the doors will lock, but the key will not work in either the drivers door or the passengers door. It won't even unlock the fuel tank. I'm guessing it's not the actuators bc the locks still move. Is it just the lock cylinder? All the threads I looked up just dealt with the actuators.
Old Feb 17, 2012 | 04:39 AM
  #32
Hope you have another key, that one sounds like it is worn down too far, or damaged somehow.
Old Feb 17, 2012 | 09:11 AM
  #33
Nope no other key! How could I get a new one for it? From VIN through Land Rover? Also, just got a call from the rad shop, the radiator was 100% blocked!! He sent me a picture of one end just to make sure I believed him. It was packed full of StopLeak and he has to rod out both ends now and it's going to be $267 and some change. Kind of downer but that sounds like my problem!!
Old Feb 17, 2012 | 09:25 AM
  #34
slanginsanjuan's Avatar
It's usually that from what I've experienced and read.
Sounds very expensive. Mine was 50-60 and Sava says it's around $100 cuz they already made the boat payments.
edit: those prices are when you take it yourself. maybe call another guy and get a quote over the phone if you take it. at least you might be able to knock a few bucks off the your guy. might as well put the new hoses on if you haven't already.
Old Feb 17, 2012 | 09:30 AM
  #35
hh65flyer's Avatar
Also sounds high to me. Mine was about 70% blocked and still came in around $100. I don't know if they had to remove both tanks or not on mine though and obviously the extra labor will cost more...
Old Feb 22, 2012 | 03:46 PM
  #36
Update:
I got all my parts back together just now, I replaced the hoses and now I don't know if the system is bled properly. How can I tell? The upper rad hose gets hot, but seems pretty soft still. There is no waterfall behind the dash and the temp stays good. I ran it for 45 min and it never budged past half way. I can't seem to find these "bleeder screws" I find people talking about. Thanks in advance!
Old Feb 22, 2012 | 04:04 PM
  #37
You don't have them, they are in the D2 setup. When I did mine, and engine was cold, I took out the radiator plug, and filled in there, and kept it up until it overflowed, with engine running, and screwed it back in, then filled a little more in the coolant reserve container. Once it warms up and opens/closes a few times you should be good. Check again every day for a few days and top off if needed. Not gurgle is one of the best sounds you will ever hear.
Old Feb 22, 2012 | 05:24 PM
  #38
That's exactly what I did good deal. I also had to reverse the heater hoses in order to remove the waterfall. But it worked!! I hope this is smoother sailing now! I'll post some pics of my progress soon! Btw does anyone know where I can get the pigtail for the front right blinker? It's burnt up and I kind of need that to pass inspection. Lol.
bambi851
Jan 12, 2013 05:15 PM
Stokkies Theron
Nov 5, 2012 07:35 AM
msm15
Jan 16, 2011 04:42 PM
Hyakku
Sep 17, 2010 08:49 PM
raedmonson
Jun 29, 2008 07:06 AM
