Anti Lock Light
Old Jun 10, 2016 | 10:12 PM
dsmeddy's Avatar
Default Anti Lock Light
97' Disco... Trying to do one job at a time and now have the Anti Lock Light to contend with. I had at one time pulled the Fuse but recently put it back in. As I hit the brakes the 1st time after start up, I get a rumble in the brake pedal and a little motor whining noise near the brake cylinder (probably the ABS module) , then the light goes out. Is this common??? Is this dangerous?
Old Jun 11, 2016 | 07:56 PM
ihscouts's Avatar
It can be dangerous if the brake pedal kicks back (pulses). You won't have brakes while it's malfunctioning, the pedal will prevent you from pushing down. There is a way of grabbing the blink code from the ABS ECU that tells you what the malfunction is and it's almost always a wheel sensor has lifted from the reluctor ring. Take a small open end wrench that fits over the wheel sensor and tap it back down until it makes contact with the reluctor (you'll feel and hear it). On the front it's the CV joint and out back it's a ring screwed onto the back side of the rotor. Give that a try and I'll look around for how to get the blink code, been awhile and didn't save the info. If tapping the wheel sensors doesn't work disable the pump fuse again....... you don't want to take unnecessary risks eh. When the system is functioning correctly the ABS light will stay on until the truck reaches 5 mph and then it goes out.
Old Jun 14, 2016 | 07:58 AM
WaltNYC's Avatar
Discovery I - ABS Blink Code Procedure
Old Jun 14, 2016 | 02:19 PM
philwarner's Avatar
I did the tapping down of the front wheel sensors to try to keep the ABS working until one day I experienced the buzzing pedal and no brakes that folks warned about and I stopped trying to make the ABS work. I have a little disk of blue painters tape stuck to the instrument panel to keep the light from distacting me at night - much better than no brakes.
thearmlesswonder
Dec 10, 2014 10:27 AM
targotsi
Sep 25, 2008 08:29 PM
redhotbuzz
Aug 25, 2008 08:32 PM
briauna2003
Aug 15, 2008 08:37 AM
sfxgamer
Jun 19, 2007 02:29 PM
