anyone been down this road - lock actuator
Old Dec 31, 2016 | 12:45 PM
rickroverover's Avatar
Default anyone been down this road - lock actuator
d1 #1 has slow, intermittent getting worse actuator on rear door.
d1 #2 works fine
piece from bone yard works fine
seems to have a cycle that gets sluggish and hard to move - indicating a dry/worn gear inside.
lock mechanism is smooth and unrestricted.
BUT no matter which one i put on the rear door it shows the same intermittent issues and is stiff to operate manually when out of sync with the other doors (normal?).
My suspicion is a weak connection or ground that is not allowing the full voltage to operate the actuator.
any ideas?
Old Dec 31, 2016 | 03:49 PM
fishEH's Avatar
I thought it was a little spring that goes bad or goes missing that causes that issue. Someone was even making and selling those exact springs I think.
Old Dec 31, 2016 | 04:16 PM
That would be a nice find.. Do you remember if that was inside the actuator? or located outside with the locking mechanism.
Thanks!!
Old Jan 1, 2017 | 08:51 AM
ihscouts's Avatar
Took me all of 5 seconds to find a how to; Fitting our replacement door lock springs Land Rover Discovery 1 Range Rover Classic REAR DOORS
Princess
Sep 18, 2011 10:02 AM
hilltoppersx
ROAMING WITH FRIENDS
Nov 17, 2009 01:43 PM
Street Wolf
Off Topic
Nov 23, 2008 04:59 PM
05LandRover
Off Topic
Apr 28, 2005 03:07 AM
