Automatic Shifter Removal Help
Old Sep 21, 2022 | 12:39 AM
Rinsel's Avatar
Default Automatic Shifter Removal Help
Hi all,
I am hoping someone can help me. I am replacing the shift surround on my 98 Discovery 1 and need to remove the automatic shifter. From what little I can find online I have taken off all the parts necessary and it should just pull up and off now. It still seems to be on tight. Below is an image I found online that shows all the parts I removed (except the shift **** itself of course). Do I just need to pull harder? Any help would be much appreciated!
Land Rover Discovery 1 Automatic Shift **** Parts
Old Sep 22, 2022 | 05:41 PM
BlackSpeed66's Avatar
Yeah just keep yanking. If that brass jam nut was tightened too much previously it may have pressed the shifter **** down on to the selector shaft too far. Maybe spray a bit of penetrating oil from above and twist side to side to try and break it loose and twist the whole thing off
Old Sep 24, 2022 | 10:11 AM
Rinsel's Avatar
Thumbs up
Thanks BlackSpeed! That ended up working. Now I just have to figure out how to fix the slop now that it is all back together. I am thinking about adding a set screw... Thanks again!
jpluncford21
Oct 28, 2016 02:12 PM
aye29
Jul 28, 2013 11:55 AM
Willie00d2
Jan 8, 2010 12:16 PM
Tvdmtac
Sep 10, 2007 02:05 PM
martinez
Engine & Internal
Jun 3, 2007 04:47 PM
