Axle Nut Torque Spec for1997 Land Rover Discovery XD
Old Sep 26, 2023 | 07:01 AM
hriant88's Avatar
Default Axle Nut Torque Spec for1997 Land Rover Discovery XD
I am planning to replace the brake rotors on my 1997 Land Rover Discovery XD which requires to remove the hub assembly off the axle.
Does anyone know the torque spec for the axle nut?
Many thanks!
Old Sep 26, 2023 | 03:13 PM
WaltNYC's Avatar
13. Fit hub adjusting nut. Tighten to 61 Nm.
14. Back off adjusting nut 90°. Tighten to 4 Nm.
This will give the required hub end float of
0,010mm
15. Fit a new lock washer.
16. Fit locknut. Tighten to 61 Nm.
17. Tab over lock washer to secure adjusting nut
and locknut."
Old Sep 26, 2023 | 09:19 PM
JohnZo's Avatar
Another method I learned on-line is to just grab the socket by hand and turn until your hand slips. I tried this and checked with the torque wrench. It ended up in spec. Thank God for YouTube.
SouthByWest
Mar 16, 2023 04:01 PM
Black.Rhino
May 3, 2021 11:02 AM
DakotaTravler
Oct 13, 2018 12:30 PM
ZGPhoto
Apr 9, 2013 01:52 PM
ajh
Nov 9, 2007 06:49 PM
