Back passenger door will not open
Old Oct 28, 2013 | 11:53 AM
Coolpines's Avatar
8th Gear
Default Back passenger door will not open
My 97 Discovery's read passenger door will not open....it feel and acts like the child proof lock is on....suggestions? Thanks
Old Oct 28, 2013 | 01:38 PM
Does it not open from the outside or inside or both?
You probably need to adjust the handle linkage.
Old Oct 29, 2013 | 10:40 AM
Coolpines's Avatar
8th Gear
Both!!
Old Oct 30, 2013 | 09:13 PM
ajnolin's Avatar
Is the outer handle frozen ? They rust at the pin hinge as soon as they can. I found one on Ebay for ten bucks, that & some skinned knuckles solved it.
Old Nov 1, 2013 | 12:01 PM
Coolpines's Avatar
8th Gear
Default 97 Land Rover back passenger door will not open.
The inner and outer handle are not frozen, and "feel" like the others that work!! The door just does not open!
Old Nov 1, 2013 | 09:26 PM
ajnolin's Avatar
well, if the inner and outer handles are moving freely, then it must be what's in between... there's a pretty good detailed picture of the linkages in Rave, there's a whole bunch of little linkage rods in there that have these little plastic retaining clips that pop off. Straightforward, just a PITA
Old Nov 4, 2013 | 01:59 PM
Mattvail's Avatar
I have the same issue. I am able to use my key to open the door but cannot just simply pull the handle.
Old Nov 8, 2013 | 10:34 AM
Mike_C's Avatar
I sprayed mine with WD-40 and afterwords it worked great from both the inside and outside. Cheap fix...
Old Nov 8, 2013 | 11:24 AM
FLA Rover's Avatar
Yep, happened to me as well. Popped out the land rover logo and saturated with PB Blaster. Good as new...
nigleg
Oct 29, 2023 07:51 PM
pgk
Feb 14, 2012 10:35 AM
tgwaldop
Jan 24, 2012 03:49 PM
Prowler9876
Feb 22, 2010 08:31 AM
