Baterry light almost on
Old Sep 26, 2011 | 12:29 PM
GLOCK3462's Avatar
Originally Posted by Spike555
Your problem is the belt is routed wrong, if it were a electrical problem it would happen all the time.
But because it only happens at warm idle that tells me your belt is wrong, it can look right and still be wrong.
When it is on wrong the alternator will turn to slow at idle to charge the battery and the battery light will come on.
interesting what you say, maybe can you tell me were can i find a diagram of the correct belt routing??
Old Sep 26, 2011 | 01:09 PM
GLOCK3462's Avatar
got it dowloaded the rave and found it thanks i will check it today
Old Sep 26, 2011 | 06:45 PM
Its in the tech section, I already posted this in your thread, maybe you missed it.
Old Oct 17, 2011 | 07:26 AM
GLOCK3462's Avatar
ok now i checked all the possible things,
1.- in my disco the belt is not just one there are 2 best one that goes from the alternator to te fan and other that goes to all of the rest (dont know if this is goos or if this version have it like this
2.- mainteinance of my alternator and thight up the belt got it done, i believe that the alternator needed a manteinance and this solved my problem
also i changed all the spark plugs and cleaned the inyectors and the acceleration system and i have another problem
when i start it cold it takes a while to stabilize, when i press the accel pedal revs come down and it seems like its going to turn off
i dont know when i cleaned the accel system maybe i put somethign wrong or i didnt put it together well, maybe you have seen this and help me
Old Oct 17, 2011 | 10:30 AM
Originally Posted by GLOCK3462
hi mi disco 94, shows a low light on the baterry inficator on the panel, when i accelertte it goes off, and when i stop again it goes low on again
maybe can someone tell me what happens
also another sympthoms that could or couldnt be associatted are
misfiring a litle when going to a lower gear
starting is difficult sometimes
stumbling when running, and it feels like cutting out sometimes when i stop accelerating
hope you can help
It sounds likee your truck gets little if any maintance. You have multiple issues. First go to a local parts store, after cleaning and tightening your cables and grounds, have the charging system tested, for zFREE, the voltage needs to be between 13.6 and 14.4 volts.
The start looking a a serious tune up, plugs, wires cap/rotor do an induction cleaning, run a can of B&G's 44K thru the gas tank.
Once it is running like it should, then look at the major service list posted at the top of this section and have it all done while your truck is still running.
Old Oct 17, 2011 | 12:36 PM
Chris-bob's Avatar
Not sure, but in Equador(where the OP is located) they may not do free checks of the charging system.
CampCobb
Aug 6, 2009 01:23 PM
luxury1
13
Feb 26, 2009 09:55 AM
Spike555
Nov 28, 2008 06:45 PM
whurst79
Jun 4, 2008 06:46 PM
kend500
Apr 24, 2006 12:00 AM
