Battery draw
Battery draw
Well, I have been having a problem starting my 1998 Disco recently. If it sits for more than 3 days, I get a slow/no crank. If I wait a week, then I don't have enough power to unlock the doors. I quick draw test showed that I had a 150mA draw. I began pulling fuses while watching my meter. When I got to fuse #12, the draw dropped to 20mA. I could hear a clicking from behind the glove box when the fuse was installed and removed. I traced the clicking to relay K151. The "interlock relay 2." I removed the relay and the draw is still at 20mA. I drove the truck home, and there doesn't seem to be any problem. My question is: What does this relay do? Do I need it in there?
On my copy of the electrical manual, section c1 page 1 tells about the transfer case interlock, which is part of the shift interlock system. Circuit on section C1 page 5 shows that K151 controls the transfer box solenoid. That keeps you from shifting out of high or low range unless tranny selector is in neutral.
