Battery draw
Old Jul 13, 2011 | 08:34 PM
jasonrusso's Avatar
Default Battery draw
Well, I have been having a problem starting my 1998 Disco recently. If it sits for more than 3 days, I get a slow/no crank. If I wait a week, then I don't have enough power to unlock the doors. I quick draw test showed that I had a 150mA draw. I began pulling fuses while watching my meter. When I got to fuse #12, the draw dropped to 20mA. I could hear a clicking from behind the glove box when the fuse was installed and removed. I traced the clicking to relay K151. The "interlock relay 2." I removed the relay and the draw is still at 20mA. I drove the truck home, and there doesn't seem to be any problem. My question is: What does this relay do? Do I need it in there?
Old Jul 13, 2011 | 09:26 PM
That is for your shift interlock.
I found out recently that when it fails it will draw power continually, it needs to wither be removed or replaced.
Is your ignition switch also warm to the touch?
Old Jul 13, 2011 | 09:30 PM
jasonrusso's Avatar
It's kind of hard to touch with the column covers on. Do I need to replace it, or can I just leave the relay out? It isn't drawing any power now.
Old Jul 13, 2011 | 09:49 PM
On my copy of the electrical manual, section c1 page 1 tells about the transfer case interlock, which is part of the shift interlock system. Circuit on section C1 page 5 shows that K151 controls the transfer box solenoid. That keeps you from shifting out of high or low range unless tranny selector is in neutral.
Old Jul 13, 2011 | 09:52 PM
jasonrusso's Avatar
Oh, It is the transfer case interlock. Thanks! This really doesn't matter to me. I don't see a scenario when I will be trying to shift into low range while driving around town. Easy, but best of all FREE fix.
Old Jul 14, 2011 | 07:55 PM
Yup, leave the fuse out.
Old Jul 14, 2011 | 08:27 PM
jasonrusso's Avatar
Well, the fuse does other things. I will leave the relay out.
vphanko
Feb 2, 2011 12:07 PM
mtfife
Jan 24, 2011 09:45 PM
jycsalas
Dec 6, 2009 06:45 AM
leeoaks
Nov 10, 2008 07:46 AM
alemurill
Aug 14, 2008 05:40 PM
