Blew something last night. Please suggest!
Old Dec 23, 2017 | 12:10 PM
Kandaje's Avatar
7th Gear
Greetings...
Not sure if it's the problem, but it seems to be leaking at the thermostat housing. We've ordered a new thermostat and gasket. Hopefully it's just the gasket that blew out. We're still awaiting the gasket.
Not a problem I've ever encountered before. 1st time for everything. Hopefully this fixes it.
Old Dec 23, 2017 | 02:49 PM
jimvw57's Avatar
Had a similar issue, ended up being the expansion tank. Only leaked when it got warm. I was told to replace it with a clear tank (white plastic), not the black tank as they seemed to fail more often. The cap that goes on the tank has the pressure relief just like a radiator cap but it doesn't look the same.
Old Dec 24, 2017 | 11:57 AM
Kandaje's Avatar
7th Gear
Greetings...
No hoses are actually leaking. Wasted a day looking for a hose.
Only suspicious thing now is the Thermostat housing gasket.
Hopefully that's it. The thermostat, and the gasket.
Typically if it's a thermostat, the engine temp would show a rapid rise.
Weird.
Chewy, I have a bad feeling about this....
Old Dec 24, 2017 | 01:04 PM
Kandaje's Avatar
7th Gear
Greetings...
More Weirdness. Interesting possibility: It's now looking like the top hose going to the thermostat may simply have become "unclamped" the clamp holding the hose slipping off the metal. There appears to be "clean" steam-washed points on the hose connection, and the body of the thermostat where the steamy coolant would have sprayed.
Once we get this figured out, maybe I can finally replace my ragged "Official Jeep Recovery Vehicle" sticker...
Still doesn't explain why it didn't over-heat on the way home. I would expect any kind of a pressure loss would result in over-heating. It was still dripping coolant the next morning. Which is why I was thinking hose to begin with. I have to keep in mind that it is a Land Rover. The OTHER shoe WILL drop!
Old Dec 25, 2017 | 06:15 AM
jimvw57's Avatar
Hoses do wear out, maybe it has become too soft internally and won't hold a clamp. or the clamp has become worn out and can't hold tightness?? I would look into replacing both to be sure. Nothing wrong with a good pressure test to be safe.
Old Dec 25, 2017 | 04:52 PM
Kandaje's Avatar
7th Gear
Greetings...
Looks like it was just the thermostat seal! Thankfully!
I can see replacing all the hoses next just to avoid headaches in the coming winter...
Thanks Guys for all your suggestions! You've all been a great help! Hopefully I'll get a camera for Xmas so I can post pictures!
olegit
Freelander
Jun 30, 2015 07:39 AM
booyah7
Aug 10, 2009 11:50 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
luxury1
13
Feb 26, 2009 09:55 AM
djones70
16
Apr 11, 2008 12:38 PM
