Transmission Questions
Old Dec 23, 2017 | 06:08 PM
aemnky606's Avatar
Default Transmission Questions
So with over 200k on the clock and a freshly rebuild engien it's time to address the Transmission. Not knowing the history I did a fluid and filter change and the fluid was dark. I do have a clunk when I go from r to d or p to r.
I'm thinking of buying a Transmission from the junk yard and rebuild it. Is that something I could do or should a shop handle this. I'm no pro but I have rebuilt a few engines.
If so what are/if any upgrades should I look into?
Old Dec 23, 2017 | 06:22 PM
ihscouts's Avatar
ZF 4HP22 step by step. | Classic Rover Forum
http://www.ashcroft-transmissions.co.uk/index.php
http://www.bimmerforums.com/forum/sh...r-4HP24-thread
The clunk is the transfer case, search Dweb.
Old Dec 23, 2017 | 07:05 PM
aemnky606's Avatar
From what I have read the clunk comes from the splines on the output shaft on Transmission Does that sound right?
The rebuild seems like something I may like doing.
Old Dec 23, 2017 | 10:43 PM
OverRover's Avatar
Before you start tearing into a trans check the condition of the drive shaft U joints and rotoflex (if still there) first.
You would be surprised how even a slightly bad joint will transfer a clunk sound, especially with a truck of this mileage.
Minimally, get out the grease gun and give the U joints a blast. Good Luck!
Old Dec 23, 2017 | 10:59 PM
aemnky606's Avatar
Rotoflex has been removed, and clunk is there with both shafts removed. I removed the rotoflex a few months back.
Just trying to find a rebuild kit. Lots out there but all seem to be a little different.
Old Dec 26, 2017 | 04:14 PM
ROB99DISCOSD's Avatar
May want to look at this too. It’s something I’m trying to get around to....
Old Dec 26, 2017 | 04:52 PM
aemnky606's Avatar
Wow, never thought of that. I will be checking that out soon. Thank you!!
tunernewb92
Jun 23, 2009 04:44 PM
Kennyr996
Mar 1, 2009 08:48 PM
avking
Feb 18, 2009 05:10 PM
toyotacrazy8180
Feb 26, 2008 11:20 PM
