Blue devil head gasket sealant
Old Apr 26, 2013 | 03:10 PM
JumPeR04's Avatar
Default Blue devil head gasket sealant
i got it cheap from ebay but i got some question about it. do i put it in radiator or reservoir... after i let it run for 45 mins then do i flush it or will it be ok
Old Apr 26, 2013 | 03:32 PM
TOM R's Avatar
I will say read the directions, some require you drain and flush the coolant out and just run it with water then re drain and re-ad coolant, some say add to coolant
so definitly READ THE DIRECTIONS
it should also give an indication on this type systembut I would guess drain the bottle some and add it there since it is more then just an expansion tank
Old Apr 27, 2013 | 08:09 PM
bcbp's Avatar
Let us know how and if it works out.
Old Apr 27, 2013 | 09:16 PM
Please don't use it. That is one of the products that guys frequently complain about. If it works, only a small quantity is used to "seal" the leak. That seal may not last a long time. The rest of the jug will sink by gravity to the lower spaces in your $700 copper radiator, where it will find scale and crud and it will block that as well. And perhaps the heater core as a bonus. So you will start overheating again. An OBDII scanner should be used to monitor the temp, your heat gauge is too "iffy".
Old Apr 27, 2013 | 11:03 PM
CUpgt's Avatar
I know I'll catch hell for this but I used k seal in my 98 for a very slow external hg coolant leak. Worked like a champ and runs at 179-185. That being said I would never pour a bottle of the thick crap in. The k seal is only 8 oz and I have had no I'll effects. I know the only way to fix a hg leak is to repair it but I simply don't have the time right now.
Old Apr 28, 2013 | 06:15 AM
JumPeR04's Avatar
thanks for all the info guys and i am like cupgt, i dont have time or the money to fix it right so i am trying to buy some time.
Old Apr 28, 2013 | 08:11 AM
CUpgt's Avatar
It really depends on the type of leak. Mine leaking externally is the reason I tried the k seal. If I was blowing coolant out the exhaust or something like that it would be a different situation.
Old Apr 28, 2013 | 08:43 AM
The Kseal has the least quantity of material to attack other places in the system, and would be a better choice. If you have a "neva flushed" radiator, with calcium and scale, or Dexcool sludge mud, it can become more blocked with large quantities of "stopz leekz" circulating in the coolant. The fabulous Rover heat gauges won't show up the increased heat problem until you open the door at the Colonel to get "extra crispy".
Old Nov 22, 2020 | 12:55 PM
dos531's Avatar
Personally, i'd rather just let it leak and add coolant than put any of that sealer crap in there. You're making way more work for yourself when you have to clean everything out.
Old Nov 23, 2020 | 07:53 AM
logan_gibson's Avatar
Loop out the heatercore before you put that in.
Otherwise youre in for a miserable time replacing that when you actually repair it correctly.
ljdiscovery
Jan 29, 2024 07:46 PM
sorbet35
Dec 11, 2013 12:36 PM
Jonathan C
Nov 15, 2012 10:22 AM
ngarover
Apr 16, 2012 09:48 PM
bikingteacher
Sep 21, 2009 09:50 PM
