brake pedal locked up on me
Old Nov 18, 2010 | 06:18 PM
Originally Posted by Spike555
Pull the fuse from the fuse box under the hood, it is the 30 amp ABS pump fuse.
In the tech section there is a "how to" read the ABS trouble code, IF you ABS light is now on all the time.
To properly fix this problem you will need to figure out what is wrong, could be a ABS wheel speed sensor, could be a bad ABS modulator.
I pulled my fuse 3 years ago, the only effect you will have besides no ABS is the ABS light will be on all the time.
I said it once and I will say it again..."tech section"
binvanna
Oct 30, 2012 12:07 PM
reconram
May 9, 2007 08:43 AM
jwmstang
Apr 12, 2007 03:46 PM
Brad S1
Nov 2, 2006 08:10 PM
Durfee
May 14, 2006 04:16 PM
