Brake Rebuild Kit?
Old Oct 16, 2011 | 02:33 PM
LeakyDisco's Avatar
Default Brake Rebuild Kit?
Hey Fellas,
I am planning on a brake overhaul on the D1.
Anyone have any experience with or opinion of the following AB kit?:
Brake Rebuilding Kit Front/Rear | Brake Parts for Land Rover & Range Rover
Thanks!
- Chris
Old Oct 16, 2011 | 03:27 PM
calebbo's Avatar
I can get you all of that for a whole lot cheaper if you want?
2 Front Rotors (British Pacific LR017951) $50
2 Rear Rotors (British Pacific LR017953) $46
4 Drive Member Joint Washers (British Pacific 571752) $1
4 Wheel Bearing Washer Locks (British Pacific FTC3179) $2
4 Inner Grease Seal (British Pacific RTC3511) $8
Front and Rear Brake Pads (Autozone) $50
(It comes with lifetime warranty, so when you need to change them just bring your old ones to the store. I've done it 4 times now and they work just fine with no squealing)
TOTAL: $157
Savings: about $200
Do your wheel bearings while you are at it
8 Timken Set 37 Wheel Bearings (Rock Auto) $78
Old Oct 19, 2011 | 01:30 PM
LeakyDisco's Avatar
TOTAL: $157
Savings: about $200
Thanks! Those parts seem awfully inexpensive. How is the quality?
Old Oct 19, 2011 | 02:56 PM
Chris-bob's Avatar
If you keep fixing your Disco...you're going to need a new screen name.
Old Oct 19, 2011 | 03:01 PM
EricTyrrell's Avatar
Like HungryHungryDisco
Old Oct 19, 2011 | 09:37 PM
calebbo's Avatar
Everything works great so far, only had them for like 2 weeks though. Rotors are nice, squeal is gone from uneven rotors. Just make sure you install the inner seal correctly or they go bye bye really fast...
Old Oct 20, 2011 | 08:55 AM
Replace the bearings, service the diffs, set the preloads on the swivels and do a 2 quart brake flush along with the kit.
Old Oct 20, 2011 | 09:04 AM
calebbo's Avatar
Question on the preload, what all do I need? I keep finding the "kits" but it's only for the upper pin. Don't we have two? I'm so confused...
Swivel pin
Bearing (which one? AB has 2)
Shims
Fish scale
CANAMDiscovery
Jan 6, 2015 05:10 PM
Chrisinhouston
Jan 6, 2015 07:00 AM
Spike555
Jun 21, 2010 07:27 PM
lipadj46
Aug 3, 2009 07:24 PM
meltdowndave
Apr 26, 2008 10:05 PM
