brakes drag/squeal around corners at highway speed
New brakes...pads rotors in front and pads in the rear. Travelling down a winding 60 mph highway last weekend the brakes (mostly front) began to squeal/squeak around curves. When I lightly step on brakes the squeal stops.
I'll admit to not doing the job myself (no time). The fact that brake pressure clamps the pads and stops the squeal rules out other driveline/axle possibilities such as CV joints.
What should I be looking into? Hub nut not sufficiently torqued?
Hub articulation. Bearings are adjustable on the DI, right? Might want to check the adjustment and correct as necessary.
If they're unit bearings like on the DII, then it's hub/ bearing replacement time.
Racer...what do you mean by 'adjustable' versus 'unit' bearings. Either way, wouldn't they squeal all time?
They are about three years old and never seen mud or wading of any kind. Hard rain is about as wet as they get.
They are SKF BR37 bearings....
CaptainCulp
Aug 24, 2013 03:17 PM
bonstarweims
Jun 21, 2010 08:44 AM
