Camel pin tow hitch for rear bumper
Old 05-06-2018 | 12:11 PM
mirrajumper's Avatar
Default Camel pin tow hitch for rear bumper
I am questioning the orientation of this assembly on the rear bumper. The silver shim plate logically should go on the rear of the hitch insert. However it only fits together without being modified on the front side.
Does this look correct?
Old 05-07-2018 | 12:10 PM
DavC's Avatar
The hitch and galvanized backing plate are only for attachment directly to a bumper, IE camel style mantec fronts or the special vehicles discovery rear bumpers.
You are using the RN hitch adapter and so do not need the backing plate (not bolting through a bumper or steel plate). Remove the galvanized plate, set aside for if you ever do a bumper mount, or need to sell the tow jaw. Front part of jaw will bolt directly to hitch receiver piece.
Old 05-07-2018 | 12:39 PM
Thanks for the pointers. Much appreciated.
Old 05-11-2018 | 09:57 PM
TOM R's Avatar
That probably bolts to the rear bumper on uk models, i have a uk rear bumper on mine , i had to ,odd the bumper since uk trucks dont have the reciever hitch
Old 05-11-2018 | 10:13 PM
Is the uk bumper strong enough? Must be a stiffer design than us model. Can you post up a comparison picture? Thanks.
Old 05-11-2018 | 11:17 PM
DavC's Avatar
3.5 ton jaw (2 bolt) is for front bumper
5 ton jaw (4 bolt) is for rear bumper
The factory rear bumper is NOT strong enough. Camel's which used the 5ton hitch were fitted with different bumpers unique to those cars, not the factory ones. For comparison just google camel trophy discovery and check those bumpers to say a normal discovery.
EDIT: the factory bumpers for camel might have only been modified in the center portion with a big welded insert, but now I cannot recall.
Defender rear cross member however has provisions for the 4 bolt style hitches either nato eyelet type or dixon bate pin type, which also need backing plate
Old 05-12-2018 | 07:12 AM
TOM R's Avatar
My uk bumper came with a steel plare that had nuts welded to it that got welded to the rear crossmember behind bumper, 4 bolt holes in bumper in middle, should be pics in my build thread towards the end
Old 05-12-2018 | 08:36 AM
rjlsierra's Avatar
my 97 d1 came with a tow hitch package and i've towed a jet ski but i'm curious as to how big of a trailer i can tow [like a 22' airstream] what are the d1's capacity,thanks
Old 05-12-2018 | 10:56 AM
Within this forum, people have quoted NAS disco 1 at a 5500lb capacity and everywhere else in the world is 7700 lb capacity.
Old 05-12-2018 | 04:35 PM
rjlsierra's Avatar
that is a nice hitch,i thought i read somewhere d1's only have a towing capacity of 2200lbs,but it's nice to know i can pull more,5500 should be enough for a decent trailer [hopefully uphill!! in the mountains]
jsaenz
04-13-2017 10:02 AM
craigalmaguer
03-21-2016 03:44 PM
Shark59
05-04-2013 10:33 PM
Fitzpatrick
02-17-2011 10:09 PM
carlitonsky
06-14-2009 12:33 AM
Quick Reply: Camel pin tow hitch for rear bumper
