Camel pin tow hitch for rear bumper
Old May 6, 2018 | 11:11 AM
mirrajumper's Avatar
Default Camel pin tow hitch for rear bumper
I am questioning the orientation of this assembly on the rear bumper. The silver shim plate logically should go on the rear of the hitch insert. However it only fits together without being modified on the front side.
Does this look correct?
Old May 7, 2018 | 11:10 AM
DavC's Avatar
The hitch and galvanized backing plate are only for attachment directly to a bumper, IE camel style mantec fronts or the special vehicles discovery rear bumpers.
You are using the RN hitch adapter and so do not need the backing plate (not bolting through a bumper or steel plate). Remove the galvanized plate, set aside for if you ever do a bumper mount, or need to sell the tow jaw. Front part of jaw will bolt directly to hitch receiver piece.
Old May 7, 2018 | 11:39 AM
Thanks for the pointers. Much appreciated.
Old May 11, 2018 | 08:57 PM
TOM R's Avatar
That probably bolts to the rear bumper on uk models, i have a uk rear bumper on mine , i had to ,odd the bumper since uk trucks dont have the reciever hitch
Old May 11, 2018 | 09:13 PM
Is the uk bumper strong enough? Must be a stiffer design than us model. Can you post up a comparison picture? Thanks.
Old May 11, 2018 | 10:17 PM
DavC's Avatar
3.5 ton jaw (2 bolt) is for front bumper
5 ton jaw (4 bolt) is for rear bumper
The factory rear bumper is NOT strong enough. Camel's which used the 5ton hitch were fitted with different bumpers unique to those cars, not the factory ones. For comparison just google camel trophy discovery and check those bumpers to say a normal discovery.
EDIT: the factory bumpers for camel might have only been modified in the center portion with a big welded insert, but now I cannot recall.
Defender rear cross member however has provisions for the 4 bolt style hitches either nato eyelet type or dixon bate pin type, which also need backing plate
Old May 12, 2018 | 06:12 AM
TOM R's Avatar
My uk bumper came with a steel plare that had nuts welded to it that got welded to the rear crossmember behind bumper, 4 bolt holes in bumper in middle, should be pics in my build thread towards the end
Old May 12, 2018 | 07:36 AM
rjlsierra's Avatar
my 97 d1 came with a tow hitch package and i've towed a jet ski but i'm curious as to how big of a trailer i can tow [like a 22' airstream] what are the d1's capacity,thanks
Old May 12, 2018 | 09:56 AM
Within this forum, people have quoted NAS disco 1 at a 5500lb capacity and everywhere else in the world is 7700 lb capacity.
Old May 12, 2018 | 03:35 PM
rjlsierra's Avatar
that is a nice hitch,i thought i read somewhere d1's only have a towing capacity of 2200lbs,but it's nice to know i can pull more,5500 should be enough for a decent trailer [hopefully uphill!! in the mountains]
jsaenz
Apr 13, 2017 09:02 AM
craigalmaguer
Mar 21, 2016 02:44 PM
Shark59
May 4, 2013 09:33 PM
Fitzpatrick
Feb 17, 2011 09:09 PM
carlitonsky
Jun 13, 2009 11:33 PM
