can anyone steer me in the right direction
i need help misfires at idle purrs when idled up codes com in up are
p1316 misfire detected first 1000 revs
p1314 misfire detected cyl not specific
p1191 fuel rail pressure sensor ckt range/performance
p1185 fuel temperature sensor B circuit malfunction
p1300 random/multiple cylinder misfire detected
I've replaced plugs with proper champions and bosch wires new fuel filter as well k&n filter cleaned. we think it may be a fuel issue as it was parked for a while new fuel has been added. another thing is the two o2 sensors ahead of the y joint have been wired together the catalytic convertor has been removed an exhaust was installed. any help would be fantastic an greatly appreciated
97 disco1 235km
97 disco1 235km
one white is tied in on the pass side to a block sorta thing three wires tied into driver side sensor the fuel was under an eighth thinking bunch of sediment an water an asst nasties got sucked up fuel was few months old new fuel in it now with antifreeze it gets slowly better with each little fix tough time trying to remove o2 sensors
You might just need to suck it up and run it bone dry, add new gas and start over adding a really good injector cleaner for a few tanks.
Being that low on fuel it def got water in it.
You need to heat up the O2's, idle the engine for 5-10 min and then using a boxed end wrench bust them loose, dont use the open end of you will round them over.
I dunno - your code reader conversion don't match the factory - such as 1191, there is no fuel pressure sensor to OBDII on a D1. Here is the GEMS list for those codes, and they seem to point to O2 issues.
O2S Upstream Heater - Hardware driver Open Circuit (both heaters) P1185
O2S Upstream Heater - Hardware driver Short Circuit P1186
O2S Upstream Heater - Inferred Open Circuit Fault (one heater) P1187
O2S Upstream Heater - Inferred Open Circuit Fault 2 (both heaters) P1188
O2S Upstream Heater Circuit Inferred Low Resistance1 Fault P1189
O2S Upstream Heater Circuit Low Resistance Fault P1190
O2S Downstream Heater - Hardware driver Open circuit (both heaters) P1191
O2S Downstream Heater - Hardware driver Short Circuit P1192
O2S Downstream Heater - Inferred Open Circuit Fault (one heater) P1193
O2S Downstream Heater - Inferred Open Circuit Fault 2 (both heaters) P1194
O2S Downstream Heater Circuit Inferred Low Resistance1 Fault P1195
O2S Downstream Heater Circuit Low Resistance Fault P1196
Took it for a spin ran alright few sputters pulled the o2 sensors they're fouled an half dozen more codes sure wish i could explain how they wired em together new codes
p1314
p1194
p1188
p1191
p1185
p1316
gonna order couple sensors shortly
p1314
p1194
p1188
p1191
p1185
p1316
csansoni
Dec 14, 2011 12:26 PM
tsuami1
Jul 15, 2010 09:39 PM
twotimeowner
Mar 20, 2010 12:02 PM
