can't shift transfer case
Old Dec 20, 2014 | 09:53 AM
nuclearw's Avatar
Originally Posted by martin12
Well fix one break two. Freed up the shifter took 15 minutes or so that picture really helped alot. Bad news it will go in gear or the slot for normal driving but it won't engage. If I put it in 4 Hi with the differential lock and slide it over in unlock and put it in gear it makes a loud gear grinding noise and won't budge. So is there a rebuild kit for the transfer case or might be better to find a working one and switch it out?
Ehh... if you get grinding its your tcase that has to be rebuilt/replaced...
Make sure you are in neutral when making changes to the shifter
Old Dec 20, 2014 | 10:16 AM
martin12's Avatar
Yeah I was in neutral while trying to shift. How hard would it be to remove the transfer case?
Old Dec 21, 2014 | 03:05 PM
nuclearw's Avatar
check the RAVE for details, its not too bad by itself.
you can open the inspection plate and look for broken/chipped gears
Old Dec 21, 2014 | 04:49 PM
martin12's Avatar
What would cause only the normal gears to be stripped while the locked gears work fine. Is that from improper shifting or what?
philwarner
Mar 15, 2015 08:22 PM
importdave
Sep 25, 2014 10:18 PM
far4cges
Aug 6, 2012 08:25 PM
ColeRover
Feb 9, 2011 07:05 AM
discoandaboat
Oct 4, 2008 07:57 AM
