cargo door hinges and paint matching
Old May 28, 2019 | 08:33 AM
WaltNYC's Avatar
Default cargo door hinges and paint matching
My wife called me and told me the rear door was broken and she could not shut it. WTF? OK. When I arrive on scene it appears the pin in the lower hinge had snapped.
After a bit of investigation I order a couple of used hinges. Apparently they used a covered top arrangement in the D2's but it is the same fitment.
My truck is Willow Green but the replacements I ordered were not so some bead blasting, sanding, priming, painting and clear coating were required.
I ordered a spray can of paint from paintscratch.com. I have to say the color match was quite good though we are talking about a small part with complex surfaces (not just a flat surface) so it isn't really critical in this application.
color match from paintscratch.com
New hinges installed.
upper....
and lower....
I did fashion a gasket out of 1/16" thick rubber to separate the hinge from the frame as I suspect it would corrode otherwise.
Old May 28, 2019 | 10:50 PM
XCELLER8's Avatar
nice job Walt,...............been there/ broke that also..lol, had to drive from Delaware to upstate NY with a strap holding the door in place. ( wife was not impressed)
Old May 29, 2019 | 07:45 AM
stillruns's Avatar
Man that sucker just broke. Nice fix.
Old May 29, 2019 | 09:28 AM
hrhoward's Avatar
willrok13
Jul 12, 2019 01:31 PM
xsramo
Aug 26, 2017 02:26 PM
bballjames
Nov 2, 2016 10:01 PM
DiscoRom
Jan 22, 2009 10:06 AM
