cats or no cats
Old Mar 28, 2011 | 03:29 AM
gmscando's Avatar
Question cats or no cats
i have a disco 1 with a faluty catalytic converter on one side can i just cut out the offending item and put streight pipe in its place but what do i have to do with the exuast sensors that are in the pipe
Old Mar 28, 2011 | 07:12 AM
kenk's Avatar
If I'm correct, there's only 1 o2 sensor per side? I would definitly leave it.
No ill effects otherwise from removing the cat, other than depending where you live, it will fail smog,or inspection, or whatever you're state calls it.
Old Mar 28, 2011 | 07:28 AM
swank1975's Avatar
Your left and right banks of o2 sensors and cats tell your engine how to fire your fuel injectors. It will have a negative impact on your already impressive fuel MPG. No sense polluting and actually breaking the law to avoid replacement parts.
Old Mar 28, 2011 | 08:43 AM
kenk's Avatar
Yea, I totally forgot to ask what year D1 it is? If it is pre-'96, you would be ok(other than legal issues), if it is '96 or later(OBD-2), you have 4-O2 sensors which reads pre- and post cat exhaust levels. Removing a cat in that case would pop you're check engine light constantly, and MIGHT affect fuel/drivibility
Old Mar 28, 2011 | 10:06 AM
Chris-bob's Avatar
Cats are evil...get dogs.
Old Mar 28, 2011 | 01:04 PM
jafir's Avatar
only the front o2 sensors will affect performance and MPG. (and like was said earlier, the 94 and 95 only have front sensors). Removing that cat, especially if it is bad, would actually improve MPG, not reduce. On a 96 and newer, it will cause the light to come on which is annoying. I had the cat replaced on my 96, because I like to know when a NEW problem starts.
Old Mar 28, 2011 | 03:13 PM
Crusader's Avatar
4wd High
I have a related question. I've got a 96 Discovery, but so far everything that I have looked at makes this vehicle look like a 95. It was made in early 96, february or march if I recall.
Is there any distinguishable differences between the 95 and 96 to tell if mine is more like a 95 than a 96?
I ask because I too was thinking of removing my cats.
Old Mar 28, 2011 | 03:42 PM
Chris-bob's Avatar
Did you look under the hood to see what engine it has?
Old Mar 28, 2011 | 04:23 PM
jafir's Avatar
Exactly. A 94-95 will have 3.9L on the intake, and will have a distributor. The 96+ will have 4.0L on the intake and coil packs.
All of the 96+ have driver and passenger airbags.
Most importantly the 10th digit of the VIN of a 1995 will be S and a 1996 will be T (this is for ALL US market cars)
Old Mar 28, 2011 | 11:51 PM
Crusader's Avatar
4wd High
Ah ok, thanks gentlemen. 4.0 is what is stamped on my intake
95DiscoSE7bullitt
Jun 1, 2007 09:02 PM
okdiscoguy
Feb 21, 2007 06:06 PM
piotrsuw
Feb 13, 2007 06:12 PM
mr mike
Jan 17, 2007 02:42 PM
riebs
Oct 24, 2006 07:00 PM
