CATS soon?
Old Nov 27, 2011 | 11:39 AM
Danny Lee 97 Disco's Avatar
It keeps popping P1316 within minutes but generally runs strong. Any ideas?
Old Nov 27, 2011 | 12:16 PM
I have no idea what that code means Danny.
Do you have a description for that code?
Old Nov 27, 2011 | 12:44 PM
ValveCoverGasket's Avatar
According to google it's a 'misfire excessive emissions' fault, but doesn't say that it's a direct result of some failed component. Though if I had to guess I would bet on O2s... Can you deal front and rears to see what happens?
Since you've already cleaned the Maf and done the ignition tuneup.
Old Nov 27, 2011 | 01:00 PM
Yeah, sounds like the path to go down.
Some threads mentioned a possible stuck exhaust valve. If that is the cause, what is best course of action and possible alternatives?
Old Nov 27, 2011 | 01:23 PM
To find out if it is a sticky exhaust valve you will need to run a compression test.
Then if it turns out to be a sticky valve you have a couple of options.
Tear the engine apart and clean it.
Or use a high detergent motor oil and do a couple of "short" oil changes.
If it continues after that then I would add some MarvelMystery oil or Seafoam to the crank case and run the hell out of it to break up and remove the sludge.
Old Nov 27, 2011 | 02:59 PM
Thanks Spike. Guess I will be doing a Rotella change soon. Maybe go ahead and run a flush type product first and then try the Rotella.
Old Nov 27, 2011 | 03:55 PM
Not a bad idea, it is rare to loose compression for reasons other than a sticky valve.
The exhaust valves have carbon cutters on them, so they dont carbon up and stick, so it has to be on the oiled side.
Old Nov 27, 2011 | 05:39 PM
ihscouts's Avatar
Coil pack, cracks, leaks. Plug wires, fuel pressure, fuel filter, injectors, vacuum leaks, pressure regulator - pinch return line see if code disappears.
You have your work cut out.
Old Nov 27, 2011 | 05:54 PM
Jake1996D1's Avatar
I have the same issue right now on bank B after taking my truck for a little swim.. It's at the shop right now getting checked out. I gave up because of ****ty weather and not having a place to work on my truck..
Here's a pic for fun
Old Nov 27, 2011 | 08:43 PM
Mine seems related to wet weather as well. Wish I had some spare coil packs.
It's running very strong 99 % of the time. It's getting frustrating I gotta get that UltraScan soon as well.
