CEL P0441 code
I wa in heavy bumper to bumper trafficentering Squirrl Hill Tunnel leaving Pittsburgh 95 degrees, AC on. Temp guage started to climb. so I turned off AC, it cooled right back down.
A little later CEL was on. Read code 0441.Reset, runnng fine, no repeat.
Any Info?
Any Info?
I am not familar with the purge valve, that is what was referenced. I guess with the increased heat, it may have stuck. It has not repeated.
Anyone else ever have any issues with the purge valve? What is it? Where is it?
Fans definitely coming on, it has run up slightly in operating temp with AC on, on really hot days at low speed in traffic. I always cut it off before it climbs much. Has happened twice now.
Any other ideas, should I be concered about fan clutch?
Danny, here's a simple version.
Fuel expands in the gas tank, for emission's sake, we don't want the fumes.
They move to the evap canister in front of W/W tank (small tube from filler neck to evap can)
When you give it gas, the purge valve releases the vapor(mixed with air) into intake (another small tube to intake) to be burned @ 14:1 ratio.
The ECU controls this.
My guess is when it was hot out, you kept stop/go, it pissed off the system. a second guess is you didn't have a full tank (shouldn't need to)
I'd inspect (you're no stranger to your lines) the lines to gas tank filler neck & vacuum to intake, might not happen again.
luck,greg
luck,greg
Adding to what Greg said, could have been "vapor lock" in the purge valve.
There is alot of heat under there and sitting in traffic like that and with the engine getting to hot (separate issues) it very well could have been vapor lock in the purge valve.
I dont know how old you are and if you are familiar with the vapor lock phenomena that was common on mechanical fuel pump engines.
It was not fun when it happened to you I can tell you that.
Please forgive my impetuance, (I think that's spelded rite) but if I'm not mistaken, on a bypass regulated EFI system, we shouldn't vapor lock
But I was wrong once b/4
Or maybe a senior moment
When you give it gas, should have read, anytime the throttle body opens (i.e. accelerating or cruising)
LOL
luck,greg
LOL
luck,greg
LOL
luck,greg
LOL
luck,greg
No fuel injection with electric fuel pumps do not vapor lock.
My point I was trying to make although not very well said was that maybe his purge valve "vapor locked" thus setting off the code.
I did not mean the engine vapor locked, but his purge valve.
I dont know if it is possible, but space travel is so why not?
