CEL P0441 code
Old Jul 29, 2010 | 05:37 PM
Danny Lee 97 Disco's Avatar
Default CEL P0441 code
I wa in heavy bumper to bumper trafficentering Squirrl Hill Tunnel leaving Pittsburgh 95 degrees, AC on. Temp guage started to climb. so I turned off AC, it cooled right back down.
A little later CEL was on. Read code 0441.Reset, runnng fine, no repeat.
Any Info?
Old Jul 30, 2010 | 03:04 AM
Long Haul's Avatar
code P0441 is a usually a bad purge valve.....might have just stuck and now working again??
Old Aug 1, 2010 | 03:42 PM
I am not familar with the purge valve, that is what was referenced. I guess with the increased heat, it may have stuck. It has not repeated.
Anyone else ever have any issues with the purge valve? What is it? Where is it?
Old Aug 1, 2010 | 03:59 PM
Rovin4life's Avatar
no nothing to do with the heat. its the ac problem. if it only overheats with the ac on then you have a problem. its possible the fans are not coming on.
Old Aug 1, 2010 | 04:07 PM
Fans definitely coming on, it has run up slightly in operating temp with AC on, on really hot days at low speed in traffic. I always cut it off before it climbs much. Has happened twice now.
Any other ideas, should I be concered about fan clutch?
Old Aug 1, 2010 | 05:31 PM
greg409's Avatar
Danny, here's a simple version.
Fuel expands in the gas tank, for emission's sake, we don't want the fumes.
They move to the evap canister in front of W/W tank (small tube from filler neck to evap can)
When you give it gas, the purge valve releases the vapor(mixed with air) into intake (another small tube to intake) to be burned @ 14:1 ratio.
The ECU controls this.
My guess is when it was hot out, you kept stop/go, it pissed off the system. a second guess is you didn't have a full tank (shouldn't need to)
I'd inspect (you're no stranger to your lines) the lines to gas tank filler neck & vacuum to intake, might not happen again.
luck,greg
Old Aug 1, 2010 | 06:40 PM
Adding to what Greg said, could have been "vapor lock" in the purge valve.
There is alot of heat under there and sitting in traffic like that and with the engine getting to hot (separate issues) it very well could have been vapor lock in the purge valve.
I dont know how old you are and if you are familiar with the vapor lock phenomena that was common on mechanical fuel pump engines.
It was not fun when it happened to you I can tell you that.
Old Aug 1, 2010 | 08:06 PM
greg409's Avatar
Please forgive my impetuance, (I think that's spelded rite) but if I'm not mistaken, on a bypass regulated EFI system, we shouldn't vapor lock
But I was wrong once b/4
Or maybe a senior moment
When you give it gas, should have read, anytime the throttle body opens (i.e. accelerating or cruising)
LOL
luck,greg
Old Aug 1, 2010 | 08:57 PM
LOL
luck,greg
Chock it up to a senior moment. LOL
No fuel injection with electric fuel pumps do not vapor lock.
My point I was trying to make although not very well said was that maybe his purge valve "vapor locked" thus setting off the code.
I did not mean the engine vapor locked, but his purge valve.
I dont know if it is possible, but space travel is so why not?
Old Aug 1, 2010 | 11:14 PM
greg409's Avatar
chock what?
luck,greg
CRB357
May 13, 2015 01:54 PM
s10lowrider1994
May 16, 2013 03:49 PM
pixel
Mar 5, 2012 12:29 PM
DV57
Mar 2, 2012 06:03 PM
Nitro96
Jan 5, 2008 10:45 AM
