Cherry Bombed The Rover..........Drone?
Old Nov 12, 2010 | 11:45 PM
Garrett's Avatar
I had my buddy's shop put on a knock off flow master and pipes and remove the resonator and muffler. I actually get a few compliments on how good it sounds.
Old Nov 13, 2010 | 12:48 AM
DiscoSux's Avatar
The only way I know to get rid of a drone is to add a resonator (another mini, pre-muffler) or get something else. I was thinking of a Flowmaster. They offer a couple versions. Unfortunately you don't know what it will sound like or drone like until someone tries it. Flowmasters are relatively inexpensive - under $100.
Old Nov 13, 2010 | 07:09 AM
Spike, go to the Cherry Bomb Vortex, mellow sounding and very little back pressure.
Old Nov 13, 2010 | 08:14 AM
shelleyman's Avatar
I have a similar problem. Had to repair the exhaust system on my 97 disco. So I went for the magna flow system from AB. Have that same drone it seems. Hate it. Liked my old sound but the stainless steel sold me on it. Tried to talk to AB for a return or a solution. They told me that's the way it sounds and it's mine. Any thoughts?
Old Nov 13, 2010 | 08:53 AM
Rover Chris's Avatar
Originally Posted by Spencerfitch
maybe.. One thing I noticed is cracking the windows significatly reduces the drone.. Not quite sure why.
actually it has to do with acoustics and resonant frequencies, think of it like this your exhaust/engine are a tuning fork and your boxy rover is a beautiful grand piano, you may not quite understand the difference but if you were inside a piano and you poked a hole in the side the resonant frequencies of the enclosure would change, the sound will be different on the inside than it will on the outside. kind of like stock exhaust vibrations they are pretty loud on the inside but aren't even noticeable on the outside. my suggestion is put the dynamat between the tuning fork and the piano!
Old Nov 13, 2010 | 02:01 PM
Spencerfitch's Avatar
Thats pretty much what im figuring. I have found that the done is only in my headspace.. Move to the center of the vehicle or rear or as far as I can to the passenger side wile going 70mph and its gone
Old Nov 13, 2010 | 02:42 PM
Mountain Goat's Avatar
Rather than Dynamat, as was suggested, a layer of mass-loaded vinyl with a layer of closed-cell foam under your carpet will pretty much silence it. Maybe a little bit of Dynamat or similar would help, but that is more for silencing panel vibrations than blocking airborne noise, which is what you are dealing with. It's expensive, but you can keep your same exhaust if you want.
I've had good luck with Cherry Bomb Turbo II mufflers, they're usually $20 or less at Auto Zone. I've never run into a resonance issue on the vehicles I've done. They are not as loud as glass packs, though.
Fivespddisco
Sights N Sounds
May 21, 2011 11:11 AM
rambino
Mar 30, 2011 08:24 PM
boldingm
Apr 21, 2010 07:56 PM
dreager1327
Nov 23, 2009 06:03 PM
05LandRover
Apr 26, 2006 10:27 AM
