Coolant Leak from Water Pump
Old May 28, 2019 | 10:08 PM
99DiscoFlyer's Avatar
Default Coolant Leak from Water Pump
Fellas,
So I've got a leak from this hole in my water pump. This is just above where the lower coolant hose flows into it.
I believe that there is supposed to be a bolt there that has somehow worked itself out? Obviously it isn't holding any coolant now as it just drains straight out of there. What sort of replacement bolt can I get to fit in there or am I completely off base?
Apologies for the crap picture, it was the best angle I could get work without removing the fan belt.
Old May 29, 2019 | 07:45 AM
OverRover's Avatar
That is 100% the Water Pump Weep Hole and it DOES NOT have any type of bolt or plug.
If the coolant is leaking from the weep hole it means the inner shaft seal is toast and it's time for a new water pump ( STC4378 ).
So by design the weep hole is doing its job because the seal failed.
Old Jun 2, 2019 | 02:57 PM
Awesome thanks!
Wesley Lueders
Aug 26, 2018 08:50 AM
clint70
Oct 22, 2015 09:08 PM
AussieDefender
Defender
Oct 4, 2010 03:10 AM
theworks001
Nov 13, 2008 08:19 PM
panther9
Aug 7, 2008 08:41 AM
