coolant tank leak
Old Oct 2, 2010 | 07:39 PM
Danny Lee 97 Disco's Avatar
If you have not already, Download the RAVE. I printed a large portion of it and put it in three ring binders with dividers. I also print whatever task I am doing and use it as a worksheet. I started keeping the signed off copies along with receipts for the parts to sort of keep up with what I have done and if the parts do have any warranty or such, I got everything associated with it together in a separate binder. Makes it all a lot simpler. Also take pics as you go, before , during and after major steps to use as a reference.
I did not always do this, but I have started that on this one. I figure on keeping this one a while. I bought an original 1973 Mustang El Grande that the original owner worked for NASA and he had a logbook that showed each and every adjustment and replacement. He would even record things like: Turned carb idle screw 1/4 turn clockwise. Dated it and signed it.
At the time I worked as a Manufacturing Engineer then a Reliability Engineer on the Cruise Missile Program, so I was accustomed to detailed work instructions ans signed off documentation. I don't go to that extreme, but I do try to keep up with it.
Old Oct 2, 2010 | 08:54 PM
pimnmike's Avatar
That is a fantastic idea. I have many leaks that I need to fix. Oil and p.s. I am going to try the stop leak from shepherd I think that is what its called for p.s. thanks Danny lee
ZMonet
Jun 24, 2016 04:00 PM
aguison
Nov 16, 2012 09:29 AM
lord.of.the.idiots
Feb 7, 2011 04:29 PM
dchyun
Oct 19, 2006 04:20 PM
