Couple calibration questions
First off I previously posted the first question in the general forum but got no answers, so....
If you put on bigger tires than stock do you need to adjust your kickdown cable. As Rave specifies setting it between speed points and larger tires will not reflect correct speeds? Meaning do you need to get paced to determine actual speeds vs displayed speeds and adjust the kickdown cable accordingly?
Second, I noticed my tach at idle is displaying around 740 I’d wager but OBD is telling me it’s closer to 640-650. About 100 points off, give or take. Any ideas on which one is likely correct, and ideas on the likely cause? Just an old wearing out gauge perhaps?
The never ending quest to get my boy dialed in...
