Cracked transfer case adaptor plate or transmission housing?
Old Aug 14, 2025 | 11:53 AM
WaltNYC's Avatar
The manuals can be found in the google drive linked in my signature. Look in the D1 section for the LT230 manual.
Download any/all the manuals and use them as you like.
Here is a direct link to the LT230 manual.....
https://drive.google.com/file/d/0Byt...lYLldhlE7s1Dtw
Old Aug 14, 2025 | 06:21 PM
ColtenM1's Avatar
Thank you. I actually downloaded them from your link a while ago but even after looking through both the transfer case and transmission manual for a couple hours I still can't find anything about the transmission output shaft. Would it be referred to by any other name? I've found the output flange but I thought that was something different.
Old Aug 15, 2025 | 07:28 AM
WaltNYC's Avatar
check out the "trans & xfer" subdirectory. There you should find the " Zf4hp22-24 transmission.pdf " file. I think you are looking for the specs starting on page 44 of that file.
direct link...
https://drive.google.com/file/d/1tY2...ew?usp=sharing
Old Aug 25, 2025 | 12:07 PM
ColtenM1's Avatar
Thanks for that link. Maybe I'm missing something but I've looked through everything and I can't find the torque specs. I talked to a friend who is a mechanical engineer and he said probably 40-50 ft lbs would be the most I should do so I went with that. Just got everything back in.
Old Aug 25, 2025 | 04:14 PM
hrhoward's Avatar
Any of this help?
Old Aug 26, 2025 | 10:09 PM
ColtenM1's Avatar
I don't think so. I think I'm looking for transmission output shaft/spline bolt or transfer case input shaft/spline so unless it goes by a different name I don't think it's on that list. Thanks though.
Old Aug 27, 2025 | 01:24 PM
hrhoward's Avatar
Gotcha.
Is it the extension shaft?
How about this.
Old Aug 27, 2025 | 10:33 PM
ColtenM1's Avatar
That's it! Thank you! looked through the manuals for hours and didn't see this anywhere. Where did you find this!
Old Aug 28, 2025 | 09:19 AM
hrhoward's Avatar
Discovery Workshop Manual, page 453, section 44, Service repair no - 44.22.04.
A search for "extension shaft" yielded eight results. Only one mention of torque spec. In the governor hub section.
eskiltell
Dec 1, 2016 04:17 PM
june82000
Sep 27, 2015 07:03 PM
Fallstaff
Apr 11, 2013 11:11 PM
Walko327
Apr 1, 2013 05:39 AM
maxman
Dec 10, 2010 12:21 AM
