Future-Proof Shock/Lift Recommendations
Old Aug 18, 2025 | 11:27 AM
Yolky's Avatar
Default Future-Proof Shock/Lift Recommendations
Hello everyone,
I have a 97' D1 that I almost exclusively drive off-road and highway to and from those spots. It currently sits on stock suspension, so I'll like to lift it 2-3", essentially as much as I can without having to go straight into the full can of worms with caster-adjusted or longer/adjustable radius arms and links etc. However, I'm open to going that direction in the future, so I'd want a shock/lift option that is fairly future-proof and wouldn't require a full set of new shocks. I know I'd have to get new longer springs of course, but does anyone have any recommendations of shocks that would be long enough for a 4-5" lift but would work in the meantime with 2-3" of lift until I decide to commit to it, maybe in a year or so?
Ideally without needing new shock mounts/towers but let me know if that's the only good way.
So far I've been considering OME 2" spring/shock kit as I've heard awesome stuff over and over again and would like an option that lasts me a while, but it seems their shocks wouldn't be long enough to take it higher in the future, although there is little overall info about shock lengths out there that I could find. Any Bilstein, Dobinsons, etc. longer and long-travel options? I've also heard that some LC 80/100 series front shocks are compatible with D1s, how about those?
It's worth noting that I'm an mech engineering student with some fabrication/manufacturing experience who loves a challenge and learning opportunity so I'd be making a bunch of my own custom parts such as shock adapters/mounts, spring spacers, adjustable links, bumper, etc. eventually or as needed.
Thanks in advance, any input is appreciated!
Cheers!
Old Aug 28, 2025 | 08:46 AM
stillruns's Avatar
Don't complicate this. Bilstein shocks with Old Man Emu (OME) springs are an excellent combo. Or, OME springs and shocks. A D1 with a proper 2in lift and tires will get you 90% where you want to go. Going higher and you risk introducing other mechanical issues that just aren't worth it for a 28 year old Land Rover. Just my two cents.
Old Aug 28, 2025 | 10:13 AM
Yolky's Avatar
Thanks for the input!
I ended up committing and going for OME springs and "longer" shocks, so looking forward to that! I was definitely overthinking this, so I'm glad I ordered the damn parts already.
Cheers
CFB14
May 1, 2025 07:34 AM
The_OGCJR
Jul 30, 2023 11:53 PM
jacobmstein
Feb 22, 2021 11:46 PM
Discolife
Jan 27, 2013 11:16 PM
ValveCoverGasket
Dec 17, 2011 04:34 PM
