Crank Sensor, o-ring?
Old Jan 15, 2012 | 02:50 PM
wheelgarage's Avatar
Default Crank Sensor, o-ring?
I am chasing down another leak. I found that oil is coming out at the crank sensor. There is no detail in RAVE I can find soft and hard copy. I also looked online parts, but could not find one that looked the one on the front cover.
Is there an O-ring on the thing?
I should have pulled it and replaced it when resealed the front cover......
Old Jan 15, 2012 | 02:52 PM
jafir's Avatar
CAM sensor.
Camshaft Sensor "O" Ring | Land Rover Engine Parts at RoverParts.com
Old Jan 15, 2012 | 05:50 PM
The crank sensor is at the flywheel and is not lubricated at all. Hell, it doesn't even actually go inside the engine.
Old Jan 15, 2012 | 10:54 PM
Yes....CAM sensor!
Thanks!
Old Jan 16, 2012 | 08:59 PM
thehun's Avatar
if you get that cam sensor off..i want a write up... icant seem to get it off
Old Jan 16, 2012 | 09:24 PM
See attached - one bolt, and it wiggles out.
File Type: pdf
Old Jan 18, 2012 | 01:50 AM
You found it!!!!!
Thanks! Yeah, I'll get to it this weekend.
Charlie_V
Aug 20, 2015 09:17 PM
cgeschwell
Feb 23, 2011 01:01 PM
leadfoot
Sep 20, 2010 01:06 PM
WIS ROVER
Sep 17, 2010 09:00 PM
stupid
Nov 23, 2008 01:17 PM
