cruise control again
Old Nov 1, 2019 | 05:56 PM
rjlsierra's Avatar
Default cruise control again
my 97 d1 with 112m miles is a great truck i've had for 20yrs,just repaired rear windows [didn't bypass power found used ecu] over the years i've had to fix cruise control a number of times so quite familiar with system.hoses are all good,diaphram good,changed brake switch,vacuum pump and ecu are left [i guess the engage switch also], my question is can i use a multimeter to add power to pump to see if it lights up? [like a power probe] been awhile since i posted cause bad health diagnosis but all you guys have been helpful in the past and appreciate the imput,thanks again btw, what i mean is if i take my multi meter and put the black wire on battery ground is there a setting on multi meter where i can touch red wire to pump to see if it works [i know there's a battery in unit]
Old Nov 2, 2019 | 11:50 AM
fishEH's Avatar
I've not seen a multimeter capable of that. But, you could just take a couple lengths of wire and touch them to your battery terminals and the other ends to the pump.
Old Nov 2, 2019 | 01:34 PM
rjlsierra's Avatar
i somehow remember someone using there multi meter like that but not sure either and yeah wire's work, found a cheap cc ecu so bought it [guess it never hurts having backup] guess i could use the mm wires!
Old Nov 2, 2019 | 10:01 PM
ihscouts's Avatar
I removed my pump because it didn't work, cleaned it up and oiled the bearings. Used a 12VDC tractor battery to test it with. Lack of use was the problem. I used it for about two weeks and went back to my right foot because it burned way more fuel than it was worth.
robert.juric
Dec 16, 2022 08:32 AM
SDinDS
Dec 8, 2020 07:54 PM
houmem24
Aug 23, 2016 11:59 AM
nelsontod
May 17, 2012 05:25 PM
sgrol
Oct 19, 2005 12:49 AM
