Crush washer for front brake caliper pipe?
Hey guys, so after I did the right front wheel bearing and brakes, I put a new caliper on it and a new metal line. Went together fine and bled fine. But today I went for a ride and the pedal went to the floor. I can see the fluid pooling in the bottom of the wheel when I stopped. I don't recall using a crush washer for the brake pipe into the caliper but I also don't recall using one on the left front or any of the backs
Is this normal? I will take the wheel off later when I get out of work to see what's going on but I am just wondering if I should pick up a kit of copper washers.
Thanks.
Thanks.
zracin
07-31-2011 03:43 PM
