Crush washer for front brake caliper pipe?
Old Jan 15, 2011 | 04:32 PM
Garrett's Avatar
Default Crush washer for front brake caliper pipe?
Hey guys, so after I did the right front wheel bearing and brakes, I put a new caliper on it and a new metal line. Went together fine and bled fine. But today I went for a ride and the pedal went to the floor. I can see the fluid pooling in the bottom of the wheel when I stopped. I don't recall using a crush washer for the brake pipe into the caliper but I also don't recall using one on the left front or any of the backs
Is this normal? I will take the wheel off later when I get out of work to see what's going on but I am just wondering if I should pick up a kit of copper washers.
Thanks.
Old Jan 16, 2011 | 08:49 AM
Garrett's Avatar
Well I figured out the problem. Fluid is going right past the top outer piston seal and just coating my brand new Brembo rotor in fluid. Getting a new caliper today, yay for warranties!
Old Jan 16, 2011 | 11:22 AM
Glad you found it, after installing the new caliper, make sure to do a full 3 pint, DOT 4 brake flush for a firmer pedal.
Old Jan 17, 2011 | 02:23 PM
Danny Lee 97 Disco's Avatar
What brand of caliper was it?
Colorado David
Jun 15, 2021 12:31 AM
vsop4me
Aug 27, 2014 09:36 AM
Rearden Steel
Jan 31, 2011 09:03 PM
krazzz
Jan 15, 2010 07:17 AM
