D1 beeps when shifter button pressed
Old May 28, 2024 | 04:59 PM
outono's Avatar
Default D1 beeps when shifter button pressed
Strange issue popped up. When the truck ignition is put into ACC, I get the normal double chime (seatbelt), but the minute I go to shift, I get a constant chime (same tone) when I hit the shifter button. It only happens when in Park and in Neutral, no other time. If I hold the button, the chime continues as a consistent noise.
I've cycled the T-Case shifter and the Trans shifter multiple times, no difference. This all popped up after I tapped the 12V wire for the CD Changer to install an accessory. I reversed the tap, but this issue persists. Any ideas?
Old May 28, 2024 | 07:19 PM
outono's Avatar
Figured it out. Fuse 12 under the front fascia had blown. Not clear why this caused beeping with the shifter in N and P, but its fixed now.
Old May 28, 2024 | 07:23 PM
JohnZo's Avatar
That must be the highly specialized "Fuse 12 is Blown" alarm function. Those clever engineers!
ononomos
Mar 2, 2022 07:05 PM
Bnoonan
Jan 26, 2020 03:39 PM
tc07
Jun 11, 2012 07:58 PM
ios1000
Feb 15, 2008 09:36 PM
ajh
May 6, 2007 06:41 PM
