D1 center console question
Old Oct 23, 2012 | 09:16 PM
bushpilot's Avatar
Default D1 center console question
I also have a center console question. I ned to replace the ribbon and lights in the shifter and was hoping someone could pass on a little info for removing the console. Should I expect any surprises or is it a straightforward procedure? My biggest concern is with the window switches and just not breaking anything. Thanks in advance, any and all info is greatly appreciated.
Old Oct 23, 2012 | 09:37 PM
honda50r's Avatar
No center console removal required. Simply pry off the black oval-shaped plastic surrounding the ribbon. Then, if you have small enough fingers you can reach in and remove the bulb and replace. Pulling back the black mat will help, too.
EDIT: Just saw you have to remove the entire ribbon. Discard my post.
Old Oct 24, 2012 | 05:54 AM
Paul Grant's Avatar
The biggest thing to remember is you are going to have to release the e-brake cable from the handle so the handle can be moved straight up enabling the console to be lifted out of place.
Old Oct 24, 2012 | 09:36 AM
yelah's Avatar
The plastic (after many years) isn't very forgiving Take your time and you should have no worries.
Fump
Dec 31, 2007 11:22 PM
sna77
Jul 10, 2007 06:02 PM
ramwheel
Apr 23, 2007 10:59 PM
BuckMontecristo
Jul 21, 2006 09:27 PM
LordOphidian
Jul 20, 2006 06:29 PM
