D1 condenser fan motors replacement
Old Sep 10, 2011 | 06:18 PM
jpscinc's Avatar
8th Gear
Default D1 condenser fan motors replacement
If anyone is interested in replacing their D1 condenser fan motors. I just did my 98 D1. Cost $34US each for the parts, plus shipping.
1996 Toyota Corolla A/C Condenser Fan Motor 88550-12130
This condenser fan motor (96 Toyota Corolla) is an exact fit minus the drain tube, so you can use the same D1 fan blades and housing. The wires will have to be spliced together as the connector is different for the toyota vs LR.
Old Sep 10, 2011 | 10:10 PM
Good post. Important note - splice wires so fans blow from grille toward engine. My PO got it reversed, and at idle I would overheat, as the condenser fan air was being "subtracted" from the radiator air flow. Of course, being the off-duty village idiot, I changed thermostat, fan clutch, radiator... before finding this.
Old Sep 11, 2011 | 06:57 AM
slanginsanjuan's Avatar
Stephen....Why did you replace that fan? What were the problems you were having. Just curious. Savannah, I'm confused are you talking about the condenser fan or fan clutch fan...or both.
Old Sep 11, 2011 | 08:44 AM
discomedic4's Avatar
Just FYI this is already a part of the tech section. Part number is listed as well.
https://landroverforums.com/forum/di...-number-31894/
Old Sep 11, 2011 | 02:41 PM
jpscinc's Avatar
8th Gear
Hi SlanginSanJaun,
The fans motors I replaced are the two that sit in front of the radiator (the AC condenser fans- if you look through the grill you see 2 fan units). The problem that I was experiencing was my D1 was overheating in stop and go traffic and on very hot days as these fan. I would turn the AC off to get the temperature down. The fans are suppose to come on when the AC is on to increase air flow through the condenser and radiator, they will also stay on for a couple of minutes if the vehicle is very hot after your turn the vehicle off.
Old Sep 11, 2011 | 02:43 PM
I'm having the same overheating problem but I don't think it's the AC fan. I need to go through the checklist again. Very discouraging.
Old Oct 26, 2018 | 05:36 PM
jpscinc's Avatar
8th Gear
26 Oct 2018 - an update - my D1 started overheating again at 180k miles. Had new water pump installed and system back flushed.
But I now notice that one condenser fan has stopped working, which I am going to replace. So a $34 part lasted 8 years, today's cost is $36.55. Not too bad.
Old Oct 30, 2018 | 10:28 AM
whiskeynipple0088's Avatar
dam - hell yeah keep on trucking!
thanks for the update - good to know
Old Oct 30, 2018 | 04:08 PM
Socal88's Avatar
Do a search for the mod to be able to turn on just the A/C fans on a separate switch, great for wheeling low speeds to keep the engine temps down.
Old Oct 30, 2018 | 11:06 PM
rickroverover's Avatar
dont forget these are notorious for having crap stuck in the radiator fins or even the fins themselves rotting out causing poor cooling. Both conditions are not easy to see without removing everything around the radiator.
Scharfire
Jul 6, 2021 02:59 PM
rlcj_racing
Jan 5, 2017 11:52 AM
Savannah Buzz
Mar 11, 2015 04:22 PM
Reza
Mar 20, 2014 07:01 AM
BoHuang
Dec 5, 2011 08:49 PM
