D1: testing MultiFunctionUnit
![Question](https://landroverforums.com/forum/images/icons/icon5.gif)
Hello,
The rear wiper doen,t operate since about a month.
All courtesy lights doesn’t switch on since last week, it doesn’t matter which door I open, the rear door including.
For the rest all the other functions are OK (rear washer, heated rear, rear fog lamp…).
I read the MFU (AMR 5360 fit my Disco 300Tdi from may 1998) can be tested. But my rear fog light switch gives only contact when the engine is switched on by the ignition key, instead of the ignition key just engaging all electrics.
- What do I wrong ?
- Where is located the courtesy lights timer ?
- And which type for replacing the rear whiper interval relais do I need ?
Thanks for educating me in the loving of sorting out some minor Disco troubles,
PierroDisco (from Belgium)
- What do I wrong ?
