D1 Trailer wiring
Old Dec 16, 2018 | 08:20 AM
RBS's Avatar
RBS
Default D1 Trailer wiring
I have read so much about the wiring and how to wire a LR's harness to everything. I bought a converter from Advance and followed directions. I ended up with running lights and nothing else. My D1 have a black plastic 7 pin round plug with 2 separate wires with a factory looking ends on them by passenger side tail light and a clear plastic harness connector with a few more than 7 pins. I am at a loss for what to do, I'm sure this has been gone over many times. Thank you for any direction I can get.
Old Dec 16, 2018 | 12:48 PM
aemnky606's Avatar
I cut off the factory 7 pin and then just make my connections.
TRUCK to CONVERTER
Black to ground
red/orange and Red/black to Tail. (There are 2 wires for the tail lights)
Green/Red to Left turn
Green/purple to Stop
Green/white to Right turn
Purple/Brown to Battery +
Old Dec 16, 2018 | 02:56 PM
RBS's Avatar
RBS
Default Done
I had everything as you say except the two wires for the tail/marker. So I soldered that on in and nothing. I have sold thicker purple wire left a green and. Row. And a red and yellow left. I don't have anything hooked to "battery". I'm not using trailer brakes just a simple 4 flat
Old Dec 16, 2018 | 03:40 PM
aemnky606's Avatar
What adapter are you using? I had to connect battery for the unit to work.
Old Dec 16, 2018 | 03:59 PM
RBS's Avatar
RBS
Default Wiring
Hopkins 311-0041-130
it looks just like yours I think
Old Dec 16, 2018 | 05:53 PM
aemnky606's Avatar
Hopkins is stating that this converter is for vehicles with led tail lights. That may be some of your problem if your wires are connected the right way.
Old Dec 16, 2018 | 08:33 PM
RBS's Avatar
RBS
I have another 98 Discovery I will check it out as well. I am wondering if my truck harness is good now it could be the trailer I'll check it tomorrow with a tester. Thank you for your help.
Landin
LR4
Jun 25, 2018 09:10 PM
Roverfanatic
Oct 5, 2015 04:01 PM
sito007
Oct 2, 2011 07:17 PM
Rdotmoon
Sep 22, 2011 10:06 PM
adamlanders
Jun 21, 2010 04:17 PM
