96 Disco 1 SD, so many questions.
Old Dec 15, 2018 | 07:57 PM
Brentski's Avatar
4th Gear
Default 96 Disco 1 SD, so many questions.
Hello fellow Rovers!,
I just recently purchased a 96 Disco 1 SD. I feel it has good bones, strong engine, solid transmission, transfer case straight rust free frame etc. The interior is a bit trashed, lots of little issues I am looking forward to addressing. I've been combing through the tech section as diligently as I can but still have questions, so many questions. Luckily, I know a few D1 owners, and planning on taping them for help in the coming new year..
First of many questions: My power steering is out, There is power steering fluid all around the pump, I believe that the seals are eaten up. I've read that there is a power steering pump rebuild/seal kit (Kotek SK-9170). Is this just for the pump used in the D2's? If so is there one for the D1?
Thanks in advance,
Brentski
Old Dec 16, 2018 | 09:31 PM
aemnky606's Avatar
Check out the D1 tech section there is a write up on using a chevy pump
https://landroverforums.com/forum/di...s-great-35013/
http://www.scribd.com/doc/53983445/D...ump-Conversion
Old Dec 17, 2018 | 08:33 AM
vanbadri's Avatar
I did the Chevy pump - honestly wouldn't recommend it, it was way more a pain in the **** than I anticipated as it's not a direct swap. Check your local junkyards and go pull every D1 PS pump you can find. One of them is bound to be good - then you might have a few backups for when that one goes.
BobE
Jun 27, 2016 04:31 PM
dipdgarage
Jan 12, 2014 10:13 AM
shortnnfd
Nov 16, 2010 02:21 AM
FargoDisco
Jun 9, 2009 08:58 PM
