D1 wont shift into overdrive
Old Oct 12, 2018 | 06:43 AM
  #21
WaltNYC's Avatar
sent you a PM
Old Oct 13, 2018 | 04:19 PM
  #22
TOM R's Avatar
Any chance 99 range rover has same trans
Old Oct 13, 2018 | 05:59 PM
  #23
ihscouts's Avatar
No even though the 4.0 uses a ZF4HP22 it is electronically controlled. The 4.6 uses a ZF4HP24 and same, a trans ECU.
Old Oct 13, 2018 | 06:15 PM
  #24
TOM R's Avatar
So basicly has to have a gems engine to be the right trans?
Old Oct 13, 2018 | 06:20 PM
  #25
ihscouts's Avatar
The GEMS Rangie is where the info is from, the Thor use EAT plus CAN Bus'd.
Old Nov 12, 2018 | 08:53 PM
  #26
TOM R's Avatar
Ive been researching this more and i found other rover sights mention the same issues i have , solution is supposed to be replace the governer at rear of trans , it cloggs and then sticks
anyone done this? Looks like it basicly drop the t case and pull tail off trans
Old Nov 14, 2021 | 07:41 AM
  #27
TOM R's Avatar
ok so i never did fix this or try getting to that governor, has anyone else had this issue and found a solution? now from sitting a brake line went and the master cylinder leaks so at some point I need to get back to this project to get her going again
Old Nov 15, 2021 | 12:08 AM
  #28
Mark G's Avatar
Honestly you need to start from square 1 and go back to basic troubleshooting: Quadruple-check engine grounds. What's the manifold vacuum (warm)? Maf voltage? Engine Temp (use an infrared temp gun to verify). Ohm out the temp sensor/s. TPS voltage. Are there one or two temp sensors? (I honestly don't know on the Gem's). Does the brake switch work properly (that would kick off the OD). Alt properly charging and Batt good? Is the odometer working properly? Any connectors or wires corroded or damaged? Tranny cable adjustment set right? Is there a switch for the high/low range which is still partially engaged or shorted? (Many vehicles disable OD in low range). Any particular fuses associated with the tranny? I'm speaking in general terms for modern EFI 4x4', some of these may not specifically pertain to the Disco 1, but I'd check them all and not rule any out just now. Write down the readings you capture. Are they well within the proper range per the Rave manual? Try resetting the computer.
I say "WELL" within the range, bc I've personally had a MAF on a VW that was at the bottom end of the 'normal' range (but a little) and the car totally ran like crap. No CEL codes. Took forever to zero in on that ...till I finally ruled everything out one by one, then broke down and spent the $60 for a new MAF. Yeah, the MAF voltage via the scanner was definitely higher with the new sensor, instantly ran great. I've also had temp sensors which had drifted and also caused shifting and engine operational problems. I'm not saying it's your MAF or temp sensor, but the point is there are a variety of factors that can cause your tranny to not engage OD. Don't skip some w/o checking.
You should rule all that basic stuff out first before condemning the tranny. Always start with the simple things, then work to the more complex (tranny). 80% of the time it's the simple things. You've already done the fluid. If you had a real good scanner, you could observe a lot of these reading and make short work of it (still check the engine temp with a separate temp gun). Or get one of the new crop of relatively inexpensive scanners that give ya real-time information. But nearly all of the sensors that matter in this case can be read on a multi-meter in a few minutes anyway by backprobing with wires. You might want to pick up an inexpensive vacuum gauge.
Old Nov 15, 2021 | 07:00 AM
  #29
TOM R's Avatar
while appreciate your input its all irrelevant this is a dumb trans not a smart one, the detent has been checked the shift cable has been checked the lines and cooler are clear and trans has been serviced since this started, read the previous posts
Old May 17, 2022 | 04:06 PM
  #30
TOM R's Avatar
i hope to fix this truck this summer, just need to figure out if im having it rebuilt or replacing used
ajnolin
Sep 15, 2015 11:43 AM
C Trus
Oct 1, 2013 04:40 PM
Spike555
Jun 20, 2012 09:24 PM
ROVERTECH15
Mar 27, 2010 10:14 AM
texmanmoore
Feb 23, 2008 09:18 PM
