D2 front driveshaft
Old Dec 2, 2011 | 03:50 PM
ESPN's Avatar
Default D2 front driveshaft
What is the whole point in putting a D2 front driveshaft on a lifted D1?
Old Dec 2, 2011 | 04:52 PM
Danny Lee 97 Disco's Avatar
The double cardon joint is the difference.
Old Dec 2, 2011 | 05:43 PM
Jake1996D1's Avatar
D1's come with a traditional 2 joint - D2's come with failure prone non greaseable double cardan drive shaft. Tom Woods is the way to go...
Here is information about the different types of shaft and why you would want one vs the other
Tom Wood's Custom Drive Shafts - Shaft Selection: CV or non-CV?
Enjoy!
Old Dec 2, 2011 | 07:36 PM
antichrist's Avatar
On a lifted D1 without castor correcting swivels and/or castor correcting radius arms lifting it will tip the diff pinion up towards the front output housing.
Single cardan u-joint propshafts should have the pinion axis and output shaft axis parallel to prevent vibration. If the pinion is pointing at the output then there should be a DC joint on the output end to prevent vibration.
robert.juric
Nov 3, 2022 06:08 PM
AaronG
Apr 1, 2012 08:00 PM
clandrovers
Oct 10, 2010 01:09 PM
98roverguy
Nov 16, 2006 06:30 PM
jusspasd
Oct 2, 2006 01:15 PM
