Front Driveshaft
Old Nov 6, 2006 | 03:45 PM
98roverguy's Avatar
Default Front Driveshaft
I need to replace my front driveshaft as I hear these are prone to failure and Im getting a humming/whinning noise at high speeds - no vibrations though. I checked atlantic british and they are $800. Is there a cheaper source or method?!?! thanks in advance.
Old Nov 6, 2006 | 03:58 PM
98roverguy's Avatar
Default RE: Front Driveshaft
I guess I'm just wondering if replaceing just the ujoints will remedy the normal cause of failure.
Old Nov 6, 2006 | 04:38 PM
geoman's Avatar
By all means---do replace the u-joints now. The only other things to fail are the splined slip-joint, but this is usually due to the shaft running for some time with an unbalance due to sloppy u-joints. The front flange can also be damaged beyond use from the u-joint cups "pounding out" the flange right before failure.
Bottom line is that if the u-joint are suspect, replace them now. It's not pretty when they fail at speed---at can be very expensive to repair the resultant damage.
regards,
Geoman
www.eurotekapg.com
Old Nov 6, 2006 | 09:14 PM
98roverguy's Avatar
Thanks bud!
Old Nov 7, 2006 | 03:08 AM
Willie 00D2's Avatar
I just replaced my front and rear driveshaft u-joints. The front u-joints in the double joint were about to break. For some reason Land Rover didn't put grease fittings in these ones. All the greasable joints were still good. I went ahead and changed them anyways because my Discovery has 97,000 miles on it. I went with greasable Precision 344 u-joints from Napa. The double joints are pretty tricky to get out. I ended up welding a bolt onto one of the bearing caps and pulled it into a big socket with a nut. Put marks on everything so you get everything oriented the way it was. There is a needle bearing in between the double joint, be careful you don't loose any pins. I stuffed a couple earplugs into the bearing to keep them all in. Also check the rubber roto-flex coupler for cracks. When they go bad they cause a lot of vibration. Shucks has a rebuilt driveshaft for $261.00 with a core. I dont' know what kind of u-joints it has.
http://www.partsamerica.com/ProductD...pe=945&ptset=A
Good luck,
Willie
Old Nov 7, 2006 | 05:41 PM
98roverguy's Avatar
Thanks for the heads up Willie. As it turns out, discos past '97 dont have the rubber roto-flex! Sweet.
Old Nov 7, 2006 | 06:05 PM
Not all 97 and newer Discos had a roto flex, bigger percentage didn't. My 99 does and I haven't had any problem with it.
Mike
Old Nov 16, 2006 | 06:30 PM
mikemeyer0's Avatar
Call GBR make order.
robert.juric
Nov 3, 2022 06:08 PM
AaronG
Apr 1, 2012 08:00 PM
clandrovers
Oct 10, 2010 01:09 PM
sneeedle
Feb 25, 2007 11:00 PM
jusspasd
Oct 2, 2006 01:15 PM
