Dash Switches Bad?
Old Nov 11, 2020 | 01:40 AM
grahamggggg's Avatar
Thanks. And thank you so much for posting all of those manuals, they've been very helpful.
Old Nov 22, 2020 | 05:19 PM
After much headache (and apparently bad luck) I've managed to at least get the rear window wiper switch working. It turns out that my issue seems to be a combination of bad switches, and some other electrical issue whereby some electronics in the car only seem to work after the car has been running for a couple of minutes (notably the rear window wiper, and rear window open/close). So, the factory new switch I got from Land Rover actually works, but only after the car has been running for a couple of minutes...I'm thinking this may have something to do with the control unit behind the glove box, since I understand the rear windows not working is a common problem due to pporly soldered joints. However, mine work, but only after the ar has been on for a couple of minutes...very strange. More to come..stay tuned.
Old Nov 23, 2020 | 06:43 PM
CantComplain's Avatar
Just out of curiosity, do you remember how the cleaning went on the rear window wiper switch? I took all of my dash switches apart and cleaned and used some dielectric grease when re-assembling. The rear wiper doesn't work (don't know for sure that it did before or not, unfortunately didn't check ahead of time. The rear wiper has a weird thin wire that seems to "float" and I'm not sure I handled it right. I didn;t remove it and it swings freely when I assemble, but once it's back together I can't see anymore. The plug seems to have power on at least some of the wires, so I don;t think it's a fuse or wiring.
ANyway, just curious what you did on this guy. I'd be for wiring in a simple toggle but I can;t seem to get it to work even if I jump the various wires.
Old Nov 24, 2020 | 12:45 PM
I remember having some of the same issues - there was the thin wire and another small contact that came off when I was taking the switch apart... I was pretty careful when taking it apart too, but still these pieces came off. I'm pretty sure I was able to get them back together properly, but I'm not sure. After cleaning, I tested the switch and it didn't work - again I'm not sure if this was because I didn't put it back together correctly, or if the car hadn't been on long enough for it to work as I described in my earlier post. Honestly, what I would do is try to get a replacement switch on eBay rather than bothering with the cleaning and wondering if you messed something up...they can be had for $20-$30. The part number for the rear wiper switch is AMR3749. I recently picked up a replacement rear fog light switch on eBay also and it works great. I notice you're in the bay area also...may be worth a trip to one of the local pick-n-pulls.
Old Nov 24, 2020 | 03:19 PM
ihscouts's Avatar
Normally when I hit a junk yard/pick-n-pull I'd take an electricians tool bag with me (with tools in it) and grab all the switches, bulbs and other smalls I could stuff in my bag. I'd grab a few parts I had to pay for too.... just saying. If you still need a window ECU contact the guys in my signature, they both sell prime parts. Sorry I couldn't help you with the bypass, never needed to use it so no experience with it.
Old Nov 29, 2020 | 12:57 AM
funny. I had posted above that I thought my rear wiper switch was busted, possibly by my own hand when trying to clean it, but sure enough it started working after I had been driving for a while. I’ll see if I can tie it to something but for now just knowing it will work after “warming up” is good enough for me.
I think I’m done with dash switches- many don’t work but I think they’re all related to the radio which was swapped with aftermarket.
Old Dec 1, 2020 | 07:23 PM
Glad to know I'm not the only one with this issue. One day I might try to figure out why the car needs to warm up first, but for now it's good enough. I have replaced several switches around the dash now (and also A/C and air recirculate switches) with known working switches (after trying perhaps 2 or 3 different switches pulled from junkyards that were apparently also bad). Every known working switch I've installed has worked. Apparently the switches on these cars are just terrible.
Relentlesspursuitof
Jul 6, 2017 10:36 AM
KingKoopa
Feb 24, 2017 10:59 AM
clarkritchie
May 25, 2016 09:30 AM
lr2001silver
Jul 16, 2012 02:27 AM
Pauljd
Nov 20, 2008 08:15 PM
