Death wobble
Old Nov 23, 2021 | 08:47 PM
dmenchaca1966's Avatar
Default Death wobble
I have a 97 disco it’s wobbling at 60+ miles an hour I just had a tires balanced it kind of stopped a little bit of it but it’s still doing it what’s the next step I should do the steering Mechanisms the front shock damper? I’ve done this before but it seem I replace a lot of the bushings and I didn’t really completely took care much of it so maybe I like to approach it a different way before replacing all of the front end bushings
Old Nov 24, 2021 | 12:00 PM
WaltNYC's Avatar
The death wobble can be brought on by several things...
- wheel bearings worn. jack up a wheel, grab the outside of the tire at 12 and 6 positions. if you can wiggle it up and down your bearings are shot.
- improper pre load on swivel ball pin. more technical and a bit involved.
- front upper shock bushings could be shot. Front shocks themselves could be shot.
- steering damper shot
Old Nov 24, 2021 | 10:10 PM
XCELLER8's Avatar
annnnnnnnd > panhard rod bolts and/or bushings worn or loose............personal experience
Old Nov 25, 2021 | 11:50 PM
jimvw57's Avatar
Start out by running 32 psi in the tires. after replacing just about everything, tire pressure made the difference. But it doesn't hurt to check everything else.
Old Nov 28, 2021 | 12:26 AM
hrhoward's Avatar
All of the above is true. I experienced the wobble but it stopped for me by doing several lock-to-lock figure eights in my yard (glorified field). ymmv
dmenchaca1966
Nov 24, 2021 12:03 PM
erick846
Jul 10, 2015 09:06 PM
brownie92
May 19, 2013 03:03 PM
brownie92
May 10, 2013 05:40 PM
jvanbelkum
Nov 4, 2004 03:48 PM
